Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > C/K
Old 04-26-2004, 02:38 PM   #1
tipler1
1998 tahoe trans problem
tahoe transmision problem
I have a 1998 tahoe 4dr 4wd, I have a problem in the 1-2 shifting , it revs up to 3000-3400 rpms and then skips 2nd gear and goes right to 3rd. hooked it up to the dtc reader and it flashes code po751. had the 1-2 shift silenoid changed but did nothing. does any one have any other ideas as far as a fix?????????????
tipler1 is offline   Reply With Quote
Old 04-26-2004, 03:13 PM   #2
Jeremy-WI
Re: 1998 tahoe trans problem
could be a problem with the 1-2 shift valve, bad seals etc
Jeremy-WI is offline   Reply With Quote
Old 04-30-2004, 11:02 AM   #3
gurrzt
Location: Poway,where God and the sun always shines, California
Your 1-2 bands maybe shot, stretched and causing the slip.
gurrzt is offline   Reply With Quote
Old 05-02-2004, 07:29 AM   #4
GMMerlin
I know stuff
GMMerlin's Avatar
I don't have my shift chart in front of me, so i have to do this from off the top of my head.
Does the trans go into 4th gear? Can you get manual 2nd?
You may have a 1-2 shift valve that is sticking, or the 2-4 band is not applying.
You can check the 2-4 accumulator for a cut seal or broken spring.
Maybe, the PCM is commanding the 1-2 solenoid to apply, but the wires to the solenoid are open or grounded not allowing the current to flow to the solenoid
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
GMMerlin is offline   Reply With Quote
Old 06-20-2004, 12:15 PM   #5
Rodie40
Rodie40's Avatar
I had problems with hard shifting and had my tranny rebuilt for $1500 and the problem is still around? what else could make this problem happen?
Rodie40 is offline   Reply With Quote
Old 06-21-2004, 07:25 AM   #6
Jeremy-WI
Rodie, you probably need some valve body work done. Do a search for P1870
Old 06-22-2004, 07:32 AM   #7
Rodie40
Rodie40's Avatar
Well, truck went back in this morn. Builder says could be a bad solenoid. will find out today.
Dan O
1966 Chevelle SS Big Block
2007 Dodge Ram HEMI
1992 Miata
1997 Pathfinder (For Sale)
2007 Camry
