Old 04-26-2004, 12:34 PM
joelyons joelyons is offline
tire size
I have just purchased a set of ADR (18 X 8.5) rims for my 99' Silverado. Does anyone know of a calculator or chart that I can use to size up some rubber for this size rim? I think I want to go with a 245/45/18. Any help would be greatly appreciated.
Old 04-26-2004, 03:27 PM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Re: tire size
Maybe try www.tirerack.com That might have some info for you to use.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 04-26-2004, 03:47 PM
buttnekked buttnekked is offline
Re: tire size
sidewall is percentage of tread width. So a 245/45 would have a tread width of 245 mm and a sidewall of (245 x .45) or 110.25 mm. Know move decimal one place to the right to change mm to cm and multiply by .3937 to convert to inches. so the sidewall is 4.34 inches. total size would be 18 + (4.34x2)8.68 or 26.68 inches tall. this isn't exact with the size charts but it will get you close enough to guestimate fit.
Old 04-27-2004, 04:41 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
If your truck is stock, you can defiantely run those tires.
*Under Construction - New sig to debut*
Old 04-27-2004, 08:39 PM
Re: tire size
my truck is @ stock ride height now but I am looking to drop it down 2/4 or 3/4 in the near future. should i go with a smaller tire if i am going to lower it? factory tire size is 255/70/16. 30.05" in total diameter. after looking @ the chart @ tirerack.com i want to go with a 255/45/18. will i have clearance problems?
Old 04-28-2004, 12:20 AM
Re: Re: tire size
Going 2/4 you can definately run the 255/45/18, but not at 3/4. My roomate has 4/6(*cough*poser*cough*) and runs a 245/40/18. But they're too small. I'm think 245/45 would probably be good at 3/4, but if 2/4 then go a little bigger. Just my suggestion.
Old 04-28-2004, 12:09 PM
Re: tire size
thanks for the advice. i'll post when i get it together and let you know how i made out.
