Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 04-25-2004, 10:21 PM
Yellwaznboy Yellwaznboy is offline
squeaky sound when accelerating from stop
Whenever I stop at a red light or coming out of my garage, as I step on the accelerator (my car's an auto *sad*), there's a squeaking noise coming from my left side...or at lest it sounded like. Sometimes I really can't tell where the sound is coming from, but it sounds like a joint on a door is loose or sounds like something's twisting. Does anyone have this problem, or if possible can someone tell me what that's caused by? Thanks.
Old 04-28-2004, 10:30 AM
starfox187 starfox187 is offline
Re: squeaky sound when accelerating from stop
have you checked your brake fluid? your brakes?
Old 04-28-2004, 10:42 AM
It's not that high pitched sound when your brakes are worn. I'm going to the dealers friday morning to check i tup.
Old 04-29-2004, 02:40 PM
shortysdrop's Avatar
shortysdrop shortysdrop is offline
Sometimes my fan clutch makes a funny noise, I need to fix it.
Old 04-29-2004, 04:14 PM
ACtually I accidentally fixed the problem by myself. I still wasn't sure exactly what the cause was, but yesterday I just wanted to check on some things under my hood. I realized that the screw that held my CAI to the car was a bit loose. So I bolted it down tighter. Then after that I was just vacuuming the inside of my car and moved my driver's seat way back, and then afterwards I moved it to where I thought was comfortable. AFter all that, my car started driving fine. So it was either the loose bolt or the position my seat was in.
