Old 04-25-2004, 08:49 PM
n8Dog89 n8Dog89 is offline
Lumina temp problems
Hi everyone...
I have a 97 Chevy Lumina. When I drive I have hot air and when I stop it goes cold?!? Can it be the heater core or thermostat? Any help would be greatly appreciated.
Nate
Old 04-26-2004, 12:35 AM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: Lumina temp problems
what does the temp gage do? might be thermostat stuck open, worn water pump, cooling fan coming on too early, or a slight blockage in the heater core. i'd have the cooling system flushed and a new thermostat installed, even if this doesn't fix the problem it's good preventitive maintenance.
Old 04-26-2004, 07:12 AM
When the car is idling the temp gauge goes up, no heat from vents, when I start to accelerate, gauge goes to middle and heat starts pouring out of vents. I am going to change the thermostat first, but I am sure there is more to it then that...
Old 04-27-2004, 06:05 PM
rruddfan21 rruddfan21 is offline
maybe heater core is clogged
Old 04-29-2004, 10:29 AM
kevinb70 kevinb70 is offline
Send a message via AIM to kevinb70 Send a message via Yahoo to kevinb70
check your coolant level. the no heat from vents would occur if you had no water flowing thru your heater core also.
