Jetta security system
I have a 1996 Jetta and I was driving along and sudenly the security alarm went on. It appears to have something to do with a fault in the sunroof but I cant be sure. I was 500 miles from home so I cut the wires to the alarm horn but then the car wouldnt start so I connected the 2 wires together. It got me home but the clock and interior lights dont work as well as other funny things. Dealer wants $600 to look at it. Independent guy took $200 to fix it but didnt.
Does anyone have a wiring diagram for the security system. Any other ideas. from Alan Young thanks |
Re: Jetta security system
If you wired the two horn wires together you may have fried the module as that would be a hot to a ground. I didn't think the anti-theft system came out untill '97, maybe you've got a late '96. Anyway, if you can't find the problem you can bypass the system by disconnecting the module (beside the fuse/relay panel) and connecting a jumper wire between pins #5 (red) and Pin #6 (red/black) of the six pin connector to keep the starter functioning.
I would change the security computer, mine had a similiar problem and this did it
i have a 95 vr6 with anti theft got same no start problem (see jetta alarm car wont start brian351w)
my 95 jetta has 10 pins at the alarm module is it possible to by pass this after reading this posting i tried to baypass some with no luck. i got one lt grey wire goes to trunk latch ,solid red(power) red white(power) black white( did nothing) red yellow turned on dash lights , black turned on vacum pump for locks small brown shorts out(fuse) one other wire shorted out fuse one wire rolled down windows then there is this heavy brown wire the same colar as the small brown wire its just as big as the red & red white wire afraid to jump to this as is might short out i am jumping all these wire off of a power wire. any thoughts to make my car run
The anti-theft module should have a 10 pin and 6 pin connector.
