04-25-2004, 07:01 PM
Car doesnt move after high psi blast?
I finally got the balls to press the HIGH BOOST button on my GSR which is 1 Bar ( 14.7 psi ). The car ran alot smoother at the higher boost than at low boost, no spittering and sputtering. The problem is that if I go through an couple gears at high boost when i let off the gas and drive like a responsible person, my car wont move at all, its just bogs and spits. All I have to do is turn the car off and then turn it back on again and it runs like a dream. Is this the result of the ECU going WTF and sending the car into kind of an limp mode?
1996 GSR w/ 1995 OBD-1 B18C1, Hondata S200 w/ P61 ECU, LS Tranny w/ Quaife LSD,ClutchMstr Stg 5,T/4 AR .60 w/ HKS Wastegate,RC 660 cc Injectors,Had Throttlebody,Skunk2 Intake Manifold,Eagle Sleeves,JE Pistons, Carrillo Rods,Stock Head & Internals,Thermal 3" Exhaust w/ no Cat,AEM Fuel Rail-Riser-UEGO-Cam Gears-Pullies-Fuel Filter,255 Fuel Pump,MSD 6A,GReddy Front Mount, 2-12's, 3 Amps,MB QuartComponents,Type-R Lip & 00 Head & Tailights,
2000 Integra Type R: Totaled
