Old 04-25-2004, 06:06 PM
violator6090 violator6090 is offline
Question Torque Converters?
what exactly does a torque converter do? should they only be used for a car you bring to the track or drive around normally? and what does it matter what stall speed you to use like 3000 or 3800?
Old 04-27-2004, 03:01 PM
Death_17 Death_17 is offline
First off a torque converter allows the engine to decouple from the rest of the drivetrain at slow speeds.it adds effective gear multiplication to get out of the hole a lot quicker. stall speed is the rpm which the torque converter effectivily locks the motor to the driveline and multiples the torque at a 1 to 1 ratio. now if your going to buy one and call someone to find out the best one for you they have to know
-compression ratio
-displacment
-cam profile
-carb or injector size
-trans model year and gear ratios
-rear end gear ratio
-weight of vehicle
-how your gonna drive it (exe. 80% street 20% track)
- and last but not least the type of car.
well hope this helped.
Old 04-27-2004, 07:41 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: Torque Converters?
the higher the stall speed the higher you can rev the engine at the launch. higher revs mean you can launch higher in the power band giving you more power at launch...
Old 04-27-2004, 08:13 PM
well how does that work with automatic?
Old 04-27-2004, 11:06 PM
DarkblueTA's Avatar
DarkblueTA DarkblueTA is offline
Send a message via AIM to DarkblueTA
Re: Re: Torque Converters?
I'm assuming you're asking how does it have different stall speeds? Its mainly the vains inside the TC. The TC slips until the stall speed is reached. ITs like taking a 6 speed, reving it up to 3500 and dropping the clutch. same concept only on an auto. most LS1 guys run at least a 3400 stall and some run as high as 4400 stall on the street.
Death 17 did a good job of explaining it.
DarkblueTA
GT70, FMIC, Alky-water injection, Hooker Cat back, 208/230 .549/.579 121LSA Cam, forged diamond pistons/eagle rods, LS6 block, Lakewood LCAs, BMR STB/PHRB/Sway Bars, poly torque arm bushing, Spec Stage 4i clutch, B&M Ripper Shifter, SLP Subframes, 60# injectors, KYB AGX shocks/struts, Moser 12 bolt(373 gears, 33 spline axles, posi, ta girdle/etc/etc/etc) and HPTuner kit
2007 Nissan Titan Daily Driver. 2* advance
Old 04-27-2004, 11:45 PM
do you have one darkblueta?
Old 04-28-2004, 01:27 AM
mixedbreedx mixedbreedx is offline
Banned
http://auto.howstuffworks.com/torque-converter.htm
this link should explain EVERYTHING you need to know, it's a great site and check out the other stuff too.
Old 04-28-2004, 09:51 AM
DarkblueTA's Avatar
Nope Torque Converters are for automatics only. I have a T56(6speed).
DarkblueTA
Old 04-28-2004, 12:33 PM
ok so say i got a 3800 torque converter. does it just give me more low end torque? what do you have to do off the line thats different? i dont quite understand. do you like rev the engine to 3800 in neutral or somthin and when it reachs 3800 u throw it into drive? or does it just give u more low end torque up to 3800 rpm?
Old 04-28-2004, 11:53 PM
well ideally what you would do is put the car in drive, hold the brake down with your left foot, and with your right foot press on the gas until the engine revved up to a point just under 3800 rpm. at that point you would release the brake and the car would launch. thats what we mean when you can launch at a higher rpm with a higher stall speed. sorry for the bad help, didnt know what you wanted to know...
Old 04-29-2004, 01:17 AM
now can u do that without a torque converter at all? or would that kill ur brakes? cuz i have 3.73's installed
Old 04-29-2004, 10:46 AM
rkdo1xa rkdo1xa is offline
What happens when you rev the engine higher than the TC's stall speed? You won't break anything, will you?
Old 04-29-2004, 11:57 AM
DarkblueTA's Avatar
You can do that...its called Neutral drop...which is what will kill your tranny faster then this fat kid going after a big mac
Just like Death said....You put your foot on the brake, bring it up to just under the stall speed(3800) and then let your foot off the brake and away you go. Its just like reving a manual to 3800 and letting the clutch out. The car will drive just like normal. As long as you don't go spinning your tires with the rear brakes on, you'll be fine.
DarkblueTA
Old 04-29-2004, 11:58 AM
DarkblueTA's Avatar
Re: Re: Re: Torque Converters?
No...you'll just spin the rear tires
DarkblueTA
Old 04-29-2004, 02:57 PM
i guess u have to hold that brake down hard, but ok that sounds easy enough ill have to get one in the future...oh and what would the labor cost on a Torque Converter is it a simple thing to install or no? could any decent mechanic do it or should professionals?
