| Let's get Technical! Discussion for hardcore in-depth motor heads! |
best swap
i have a 91 accord ex. which engine swap would be best to go with if i want to add a turbo
Good question, but if you get an H22A then you will have to down the compression if you want to run a lot of boost. I assume you probably have an F22A right now, so you could replace some of the internals (pistons, rods, maybe sleeve it, etc) then add the turbo.
If you're set on the swap, and are looking to do something interesting, see if you can find an F20B , should be the engine used in the Accord SiR. However, I think the F20B runs pretty high compression also, like 11:1. |
Check out www.andrewsimportperformance.com they have like all kinds of low miles rebuilt motors, trans and ecu packs. The have a guide for what motor u need too.
Re: best swap
Well if you are not going to do any block work and boost the stock block, then I say go with the b18b ls motor. But if you have enought money to get say new pistons, and rods..etc. then I say go with the b18c1 gsr motor! What is you power goal? A stock ls block boosted at 10psi with a kit can make 250whp, and the ls block can easily handle 12psi. It also comes down to budget, the cheapest would be go ls turbo, but if you got the cash for the more expensive motor, and you can dump money into rods and pistons, then gsr motor is deff. my pic.
Re: Re: best swap
88 Honda CRX Si - B16 90 Honda CRX Si - B20VTEC |
Re: best swap
i agree with jajimo on the h22a. slightly larger displacement meaning 30% increase in hp and 8% increase in torque over the f22b. the f20b would be a good motor also.
Re: Re: Re: best swap
Guess i was in too much of a hury at the time. So in that case scratch that, and go with the h22a.
I say h23 actually, since he plans for turbo.
Re: best swap
Re: best swap
not alot of opp for a turbo best to go all motor. so get a h22a or f20b and call it a day.
Re: best swap
once you boost you'll never go back
Re: Re: best swap
![]() CHECK OUT MY CARS HERE! drag1320neon and 209neon's babys < 209 neon finished!> |
Re: Re: Re: Re: best swap
