Old 04-25-2004, 04:56 PM
Indyrider Indyrider is offline
Question 98 elect window prob
My drivers side front window went down, now it wont come back up! All the other windows work fine. When I push the button to make the window go up nothing happens, but when I push the down button I hear a click under the dash. Any help to point me in the right direction would be greatly appreciated!! Thanks!!!
Old 05-05-2004, 11:47 PM
CrackALaid CrackALaid is offline
Send a message via AIM to CrackALaid
Re: 98 elect window prob
OMG, Exact Same Problem, Need Answer as well... Please Msg me on AIM with fix - CrackALaid
Old 05-06-2004, 03:24 PM
james 420 james 420 is offline
Angry 98 ford taurus window probelm{drivers side}
98 ford taurus driver window problem also let figure this shit out guys!!!!!! all my othere windows work also. except my drivers side it went up one time and worked all day but it stopped working again i get the same clicking noise from the relay wich is the one touch auto window relay what you are hearing under the dash
Old 05-07-2004, 11:36 PM
James Please Hit Me Up If You Find The Answer, I Need It Quickly, and Dont Have Much $$ To Spend =/
Old 05-08-2004, 05:34 PM
irish30's Avatar
irish30 irish30 is offline
window troubles
There are a few areas to look.Tuarus' ahve problems with the master control switch on the drivers side. Water gets into the switch from windows being open in the rain or in drive thru, fast food stops. The contacts inside this switch get corroded. Also in the jam of the door,wiring in this area breaks from the door being opened and closed. The other is the wiper motor itself. If there is power through the switch to the motor wiring you need a new motor. "Why only this window", it gets the most use. I am a Ford Technician and I see this all the time. I own a 1998 Taurus SE 3.0 ltr as well.
Old 05-10-2004, 05:50 PM
irish30's Avatar
How did you make out?
Old 05-11-2004, 09:40 PM
nhdego nhdego is offline
I have same problem. only exception is the interior light will stay on also. may be two different problems. has only do it three times and it seemed to reset itself. The water reasoning sounds probabable as I do see water from time to time when it rains coming in w/window open. have replced relay w/no help.
Old 05-11-2004, 10:23 PM
irish30's Avatar
In your door latch is a door ajar switch. Most of the time they need lubrication. Spray the latch with spray grease or or even WD40. It will free up the door ajar switch. If this switch is open it will leave your lights on. Do you want to diag and repair the window problem yourself?
Old 05-12-2004, 08:48 PM
Hey Irish, is there any way to get the window up if your motor is bad??
Old 05-12-2004, 09:05 PM
irish30's Avatar
You have to remove the door panel, but somtimes tapping the window motor with a hammer and trying to put it up will work. Other than that not really, unless you remove the motor and push the window up by hand. The only problem with this is the motor keeps the window up.
Old 05-12-2004, 09:50 PM
Thanks for the quick reply Irish!! I'll try tapping and let you know. Thanks again.
Old 05-12-2004, 10:05 PM
irish30's Avatar
If you need to or want to diag it yourself let me know. I can walk you through it. I have access to all the wiring diagrams and pinpoint tests from Ford.
Old 05-14-2004, 10:53 PM
Well my window is still down, havent had a day off work to work on it. I'm goin to try to tap it with a hammer to see if that works, and if it doesnt guess I will have to buy a used motor. I just want the damn window up!
Old 05-14-2004, 11:24 PM
irish30's Avatar
Hope you live in a nice neibourhood with your window down. If you need any more lt me Know bud.
Old 05-17-2004, 04:17 PM
pray4mojo pray4mojo is offline
I had a similiar electric problem where the door locks would be going up and down constantly. This would happen while driving or when the car is parked and the iginition is turned off.
Any ideas guys?
