Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 04-25-2004, 03:30 PM
easyE101 easyE101 is offline
P1582 Engine Code...???
YEAH.. i have a 96 jetta gls 2.0 and the check engine light has been on now for about a year now i had a diagnostic done on it and the P1582 code came up saying 'idle adaptation at limit' ...hmm.. if anybody has a cure to this problem PLEASE HELP!!!
Old 04-26-2004, 05:13 PM
boschmann boschmann is offline
Re: P1582 Engine Code...???
VW proceedure says to first change engine oil & clear code (you can disconnect the battery for 10 seconds). It's a pain of a code to get. It could be alot of things, oil dilution, throttle valve, fuel pressure and associated problems, injectors.... Most common seems to be the throttle valve goes bad.
Old 04-27-2004, 04:01 PM
anton-99 anton-99 is offline
Search through the Jetta forum that this thread was posted in for "P1582", there are several threads discussing the matter.
My '96 Jetta 2.0 L was giving me the same code for awhile as well, though it wasn't running too bad. I cleaned some things up (throttle body) and had the code cleared and it has yet to return. Best of luck to ya.
Old 04-28-2004, 05:04 PM
STARCHIEF56 STARCHIEF56 is offline
P1582 Code
TAKE THE ADVICE FROM ANTON-99,I HAD THE SAME PROBLEM WITH MY 96 JETTA.I CLEANED OUT THE THROTTLE BODY AND MAF SENSOR,WENT TO AUTOZONE AND HAD THEM RESET THE ENGINE LIGHT.RAN FOR A WEEK AND HAD MY CAR SMOGGED ,PASSED WITH FLYING COLORS.IT HAS ABOUT 100 MILES ON IT SINCE THE REPAIR WAS DONE.THANKS AGAIN ANTON-99.
Old 04-29-2004, 06:43 PM
thanks guys for your feedback. the only thing i need help on is the removal of the throttle body. it doesn't look that bad but if anybody has done this before and would like to share some tips to make it a little easier for me please do so... thank you.
