Old 04-25-2004, 03:26 PM
superman0604 superman0604 is offline
Wiring
I have 2 single voice coil subwoofers and an amp that is 2 ohm stereo stable. How would I need to wire these up? (Parallel or series)
Old 04-25-2004, 04:17 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Wiring
what impedence is each sub?
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 04-25-2004, 05:04 PM
Sorry. Each sub is 4 ohm ipmedance.
Old 04-25-2004, 06:56 PM
sr20de4evr's Avatar
Re: Wiring
then do parallel
'01 Black Sentra SE
'05 Silver WRX STi
Old 04-25-2004, 09:22 PM
I have a 2 channel amp right now so would I just hook them both into one channel? Sorry for all the questions, kinda new to this.
Old 04-25-2004, 10:26 PM
sr20de4evr's Avatar
Re: Wiring
ah shit I forgot you said you had a stereo amp
You have two choices, either wire the subs in parallel and attach them to one channel, or wire each sub to each channel individually. Either way should give you about the same amount of power going to each sub, and neither will optimise the setup. I would just wire each sub to each channel.
'01 Black Sentra SE
'05 Silver WRX STi
Old 04-26-2004, 02:24 PM
What is different between a stereo amp and a regular amp?
Old 04-26-2004, 03:17 PM
sr20de4evr's Avatar
Re: Wiring
Well, the only differences between amps (ignoring different classes) is the number of channels. At first I was thinking you said you had a mono amp that was 2ohm stable. But in fact you have a 2ch amp that is 2ohm stable per channel, which means it's only 4ohm stable when bridged (combining both channels into one, so it acts like a mono amp). Because it's a 2ch amp and it isn't stable at 2ohm bridged then you have to wire each sub to each channel separately. This will give you whatever the stereo 4ohm power rating is.
'01 Black Sentra SE
'05 Silver WRX STi
Old 04-26-2004, 05:28 PM
Thank you for all your help. You have cleared up a few things for me. Thanks.
