Old 04-25-2004, 02:02 PM
jazer80 jazer80 is offline
smell gasoline when flooring it?
whenever i floor my car (and make vtec engage) i can smell gasoline. any ideas how to begin tackling this problem?
I would love to see a special where thay show the getaways, they could call it "Worlds shortest police chases" Then Johnny Bunnell could say something like "Officer Bobby Ray Gasshall floored it but he soon found out that his Crown Vic is no match for Johnny Tran's S-2000" -jrbump
Old 04-26-2004, 01:34 AM
SenseiAccord SenseiAccord is offline
Re: smell gasoline when flooring it?
running rich? most cars run a lil rich at full throttle but still in the good air/fuel mixture range. Also if ur engine is still a lil cold it will run a lil rich too.
Old 04-27-2004, 11:14 AM
no i mean it smells like your using a lawnmower, and this happens warm or cold, just every time you floor it. could it be leaking gasoline dependent upon pressure?
Old 04-27-2004, 06:50 PM
92lx 92lx is offline
possibly what I had, a slightly leaking fuel injector (only at higher pressures it would leak through the gasket). Also you may be running mega rich for some reason or another.
-Nathan
Old 04-27-2004, 08:33 PM
if it was running real rich wouldn't i smell it a little all the time? if it's a leak you think it would be in the fuel injector?
Old 04-29-2004, 12:25 PM
integrasedan integrasedan is offline
check your fuel filter for leaks and the hose condition for leaks. good time to change fuel filter too.
Old 06-06-2004, 06:24 PM
slabertooch slabertooch is offline
your exhaust gasket might be faulty too, high pressure hot gases could be causing your gasket to expand and leaking, creating that gas smell. A good way to check is to spray some dishwashing detergent on it and start it up. have someone underneath watching for bubbles when you floor it. If you get bubbles you have a leak, no bubbles, look elsewhere.
challange the status quo. live YOUR life.
Old 06-06-2004, 06:30 PM
well my exhaust manifold does have some leaks, but the smell from that isn't what i'm dealing w/. i smell fresh, unburnt gasoline
Old 06-06-2004, 06:32 PM
my pcv valve (abbr?) seemed to have some leaking, and i think that's where unburnt gas recirculates, so maybe that's it. gonna put a clamp on it and see if that helps. too busy w/ damn electrical problems (only have 1 headlight bulb working out of 4!!! electrical problems SUCK!!!)
