Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 04-25-2004, 10:12 AM
FSJer FSJer is offline
Question GC Brakes
Has anyone used the rotors, pads etc from the aftermarket people. There are several aftermarket brake mfg that say they can cure the poor brakes of the GC. For example, EBC makes rotors, pads, etc as well as Stainless Steel brake co. and Wilwood $$$$$, and even Raybestos makes drilled slotted rotors and better pads. Has anyone used these, and how did you like them?
Old 04-25-2004, 05:29 PM
Dsilver Dsilver is offline
Send a message via AIM to Dsilver Send a message via MSN to Dsilver
Re: GC Brakes
Im not sure, the brakes on my GC are just fine so far, but trying talking to Dale Aeppli, he might have some info for you.
Old 04-25-2004, 06:13 PM
jeepfixitman jeepfixitman is offline
Send a message via AIM to jeepfixitman
Re: GC Brakes
If it is a 99-2002 grand it is likely the calipers not the brake parts that are the issue. There is a tsb out where we have been replacing calipers pads and rotors for warped rotors it seems the calipers dont always fully release therfore causing extra heat that warps the rotors, resurfacing or replacing pads and rotors wont help if this is the cause.
Old 04-25-2004, 10:50 PM
Re: GC Brakes
This is a 98 GC. The Brakes on my sisters, and ours are equally bad. Looks like EBC gets about $800 for drilled/slotted rotors, and pads. Stillen is $3000 for thier set up. I don't have a response from Stainless Steel Brake yet. Raybestos sells a slotted drilled rotor for the front, but nothing for the back.
Old 04-26-2004, 08:56 PM
Re: GC Brakes
Go with the Stillen or something similar, get some kick a$$ brakes if you have the money
Old 06-13-2004, 03:45 PM
pharaoh1976 pharaoh1976 is offline
Re: GC Brakes
You can get the Mopar Updated Calipers, pads, and rotors to fix this problem. The price for all the parts is about 300. I hope this helps
Old 07-13-2004, 07:18 PM
ArLouJeep ArLouJeep is offline
Brake Rotors
There are several different rotors out there. Stillen recommends the crossdrilled rotore to dissapate heat, since heat is the cause of the warpage in the first place. You can go to www.stillen.com The price of the rotors is 196.00 per set, and another 100 dollars for the pads. They said that they see a lot of jeep GC problems, and the keep these pard and rotors in stock.
