Old 04-25-2004, 01:53 AM
kambahou kambahou is offline
need help 3000 gt 93
I have a 93 3000 gt twin turbo v4 and would like to know what each of the amber warning lights on the dashboard mean.
Old 04-25-2004, 01:49 PM
Teazrsnow Teazrsnow is offline
Send a message via AIM to Teazrsnow Send a message via Yahoo to Teazrsnow
Re: need help 3000 gt 93
you gotta be a little more descriptive, ihaven't seen em for a while
Tyler Laabs
2nd Place Drag racing Fwd 3s National Gathering 03[
Old 04-25-2004, 01:53 PM
Igovert500's Avatar
blue + red light magnet
Is there a specific light you are wondering about?
I'll check out all of mine when it stops pouring outside and give you a complete list.
Here is a picture of it, if you can zoom in it might help us to identify specific lights.
http://www.team3s.com/STIM91/Images/tim_08-13.gif
Don't you have a service manual in your car?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 04-25-2004, 02:34 PM
Igovert500's Avatar
ok, got em...this is for a 96 vr4, but I'd assume they are most likely the same.
Starting top left column(top to bottom)
1.door-ajar warning light
2. oil pressure warning light(wl)
3.check engine wl
4. is a blank space without a light
5. securiy indicator(for theft-alarm, if so equipped)
Then you have the Tachometer
in the middle under your turning signals and fuel gauge:
1st space down has two lights:
on the left half its: 4-wheel steering oil level wl(if so equipped)
on the right half: Brake warning light
in the 2nd space down: Anti-lock brake wl (if so equipped)
3rd down is split in halves again
on the left: cruise control indicator(if equipped)
on the right: cruise control ON indicator(if equipped)
4th space down:
on the left: charging system wl(battery)
on the right: High-beam indicator
THen you have the speedometer
on the far right:
first space = blank/unused
2nd down-seatbelt wl
3rd-washer fluid(remember there are 2 reseviours, one in the engine bay and one in the trunk
4th- supplemental restraint system(SRS)(airbag) wl
5th down- is split in halves again
on the left: active AERO system wl(if so equipped)
on the right: engine coolant level wl
That is all of them. hope it helps.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 04-26-2004, 12:39 AM
Thank you very much, this helps me a lot .
The car is fully loaded ,and has the same red colour
but I have the tilting headlights instead .
Thank you again
