Old 04-25-2004, 01:36 AM
billybob403 billybob403 is offline
reflectors or Lights on Door panels? 97+
I have a 98 GT 4-door. Each door has a clear red lense. I can see a hole where a bulb would likely fit. Do all grand prix's or GT's for that matter have the wire harness to put bulbs in the lenses, or do I possibly have door panels from a GTP. I am trying to prevent pulling the panel off just to find out I do not have a harness, but if there is one there would like the bulbs to be there as well. Is there a reason someone would have pulled the bulbs and not replaced them? Are they prone to shorting out? any info is appreciated.
Old 04-25-2004, 01:38 AM
Re: reflectors or Lights on Door panels? 97+
also, what is the recommended procedure to remove the door panels, is it best to begin prying at the bottom or?
Old 04-25-2004, 08:40 AM
cayton69 cayton69 is offline
in my GTP the lens assembly just popped out. i think all it took was a screw driver to pry it out. before you take the door apart i'd try to carefully pry and see what happens.
Old 04-25-2004, 02:08 PM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
I would love to install bulbs on the rear doors but the cabling is not there. On front the white lens is the one with bulbs inside(I do not remember seen the red ones with bulbs inside)
Old 04-26-2004, 01:02 AM
GTPgirl's Avatar
GTPgirl GTPgirl is offline
Send a message via ICQ to GTPgirl Send a message via AIM to GTPgirl Send a message via Yahoo to GTPgirl
Open your trunk and look at your RPO codes. If the code "CR1" is on the sticker, then the front doors have lights. The rear doors are just reflectors. Then you don't even have to pry out the lenses to see.
GTPgirl
Black 1998 Camaro - currently driving
Black 1999 Grand Prix GTP - burned March 2008
Plum Crazy 1970 Dodge Challenger - work in progress!
