Old 04-24-2004, 11:34 PM
civicrider187 civicrider187 is offline
clutch adjustment need help
i need to adjust my clutch but cant figure it out,i found the adjuster nut and tried that didnt help, the clutch seems to be not as tight as it should be. If anyone has any info for me that would be much appreciated
Old 04-24-2004, 11:44 PM
optimuscivic's Avatar
optimuscivic optimuscivic is offline
Re: clutch adjustment need help
do you mean the clutch cable? or the actual clutch?
As American As A Burrito!
USDM 4 life!
Old 04-25-2004, 12:38 AM
88ReX 88ReX is offline
On the topic of adjusting clutches, which way should I turn it if my clutch enguages (meaning I am releasing the pedal) too soon and it's hard to get it into gear? It seems to take more effort than it should to put it in gear, too much resistance. I think this is due to the fact that my clutch is engaugeing too soon or that it doesn't fully disengauge.
"us FartoX guys are intelligent, excellent drivers who would never stoop to levels of pure testosterone"~Earlsfat
Old 04-25-2004, 12:43 AM
i know what your talking about, your clutch cable is too tight, it needs to be loosen.
USDM 4 life!
Old 04-25-2004, 03:32 AM
Re: Re: clutch adjustment need help
So which way do I turn the knob?
Old 04-25-2004, 01:50 PM
Re: Re: Re: clutch adjustment need help
Will someone confirm this, I need to turn it left to loosen the cable?
Old 04-25-2004, 01:54 PM
quiXilver's Avatar
quiXilver quiXilver is offline
Send a message via ICQ to quiXilver Send a message via AIM to quiXilver Send a message via Yahoo to quiXilver
turn the adjustment (near the battery) counter-clockwise...i had the same problem, you should feel it get looser, if that makes it worse go the other way.
http://www.cardomain.com/quixilver09
B18A
-It's always somethin'
Old 04-25-2004, 03:26 PM
shaddr3 shaddr3 is offline
Send a message via AIM to shaddr3
Righty Tighty,
Lefty Loosey.
If its really tight, then once you put it in gear and let off the clutch, the car with jump into gear. Making it really loose gives it a slower reaction. When I bought my CRX, it was soo tight that once I put it in 1st, it literally jumped 10 feet in a second.
I hope this helps you out.
89 CRX Si
B16 | BW Body kit | 17" 8 Spoke | Airbagged
Old 04-25-2004, 04:34 PM
i already adjusted the cable,no diff,so I should adjust the adjusting bolt? Is it just above the pedal inside the car?
