Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 04-24-2004, 04:12 PM
tonybu tonybu is offline
gauge problem
i have an '98 jimmy and about a week ago the tach and speedometer started to flucuate and evetualy stopped working. i saw the earlier post about the ignition switch and it sounds like the same problem. on start up the tach will jump then go out also the gas hand wont work but the oil pres. and batt work. it also wont alow the key to come out without coaxing. the strangest thing is when i push the trip odometer all gauges work fine.also the trans is not shifting. any help will be wonderful as i said before it souns like the early post of a bad ing. switch
sorry for such a long post.
Old 04-25-2004, 08:55 AM
michelq michelq is offline
Re: gauge problem
it is bad ign switch
Old 04-25-2004, 10:44 PM
thanks
thanks the ign. switch at sixty bucks is better than 300 for a guage cluster
Old 04-26-2004, 05:20 PM
Re: gauge problem
good for you!
Old 05-07-2004, 08:48 PM
Talking thanks
changed the switch good as new. i would have never thought of that thanks for the info.
Old 07-22-2005, 04:16 PM
stargehzer stargehzer is offline
Re: thanks
Where did you fing an ignition switch for $60 ?? I haven't been able to find one for less than about $90 and money is tight right now. Thanks in advance!!
Old 07-22-2005, 08:04 PM
Re: gauge problem
check the autozone website its listed for 45.99
