Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 04-24-2004, 03:44 PM
papabear92499 papabear92499 is offline
replacing antenna
Does anyone know how to replace a motorized antenna on a 92 grand marquis? Seems it is in a real tight spot. I have a Metra RoadWorks replacement but have no idea how to take the original out.
Old 05-18-2004, 01:54 PM
clydes270 clydes270 is offline
Registered User
Send a message via AIM to clydes270
Re: replacing antenna
I have a 1993. Changed the antenna to an automatic from K-Mart.
1. Turn off the Auto Syspension in the trunk.
2. Raise up front of car and use jack stands.
3. Remove right wheel.
4. Remove battery top clamp, then battery.
5. Remove nuts and push pins from wheel well.
6. From above wheel well, remove all items held in place by push pins.
7. Lift up on wheel well and be careful with battery
tray area. Remove wheel well.
8. Remove plastic cover hiding power antenna with push pin at top.
9. Remove top crown nut holding power antenna mast in place. Use needle nose pliers.
10. Remove bolt holding antenna to fender.
11. Remove right kick panel inside of passenger compartment.
12. Remove cover under dashboard and under glove box.
13. Remove glove box hinge screws at bottom, open box, then push sides together.
14. Remove radio to remove antenna cable.
15. Pull antenna cable from dash then outside to wheel area.
16. Unplug two wire connector for antenna. Remove wire.
Old 10-09-2004, 09:16 AM
labluebeer labluebeer is offline
Send a message via Yahoo to labluebeer
Holly crap, just put a good boom box in the back seat and seat belt it in. Kids can sit in the trunk. problem solved
