Old 04-24-2004, 03:21 PM
Cynister Cynister is offline
Send a message via Yahoo to Cynister
Coolant system mystery
I have a 93 lumina 3.1 and it had a bad radiator, i got the leak fixed but now it still will shudder and die after a decent drive. it will even say low coolant. but the coolant level is fine. Is this a vacuum problem or something worse?
Old 04-25-2004, 08:49 PM
codboy codboy is offline
Re: Coolant system mystery
system probably has a air lock and needs to be bled
Old 04-26-2004, 12:31 AM
amac209 amac209 is offline
Send a message via MSN to amac209
theres a switch in the overflow tank that turns the light on. try tapping the side of the tank with a screwdriver handle. if the doesn't work remove the tank and shake it a few times, then it will probably work fine.
good luck
