NEEDED: circuit diagram ABS 91 Park Ave
I have got apparently some trouble with my ABS (retrieving error code A061). The warn lamp is always on in the meantime.
Well, could anybody assist me with such a circuit diagram in email? I want to check as much as I can before installing a new expansive ABS pump... Thank you very much in advance °MV |
Guckst Du Mehl
1991 Buick Park Avenue 1995 Ford Fiesta Waghaeusel/Germany |
If your 91 is the same as my '95, my '95 shop manual shows 3 pages of tests to be done. Possible causes are open/shorted circuits from the EBTCM to PVM, failed ABS pump relay, or failed components (EBTCM< PVM). The code 61 usually sets while the vehicle is moving during the "self test". DTC61 also sets when the pump motor runs all the time. You did not mention this so I assume this is not the problem. You wil probably need a Tech I to perform the tests but you can examine the wires and connections carefully. I had mice in my engine compartment that chewed on wires and made a nest in the air filter. A relay would be an inexpensive guess. GOOD LUCK.
