Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 04-24-2004, 01:47 PM
trav8so trav8so is offline
Tire Size On Civic
wHAT IS THE LARGEST TIRE I COULD PUT ON A 98 CIVIC WITH 17
Old 04-24-2004, 10:50 PM
Bxcivic2000 Bxcivic2000 is offline
I have been doing some research on this and you better be careful what tires you put on your car. If I am not mistaken the biggest tires you can put on your car are 205/40/17. But you can check out www.tirerack.com and there you can look up that's the best tires and wheels for your car.
In my experience with another car, I changed the from the stock size tires to a smaller size tires but wider and I ended with a damage tranny, cause once you cnage the tires you are changing the tranny's gear ratio, and this is something that you dont want to mess around with. So do you homework
Good Luck
Bxcivic2000
