temperature gauge?
i think my temp gauge is reading wrong, b/c it always seems to be running cold but when i pop my hood its hot as hell. when it gets really hot my car leaks, what appears to be water. but when i look to see where its coming from the only place i see that is wet is the "radiator coolant" fillup jug. this monday im going to flush my entire coolant system and look over all that i can. does anyone know whats goin on? or how i can test to see if my gauges are reading right?
2.3L pumpin out 105 stock horses, WHAT NOW BISHES |
If you think you have a leak, hook up a pressure tester. Works great. I'd also suggest to replace the stat while your in there.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears. |
Re: temperature gauge?
which stat should i get? a 180 or a 160?
stock replacement! I believe HiFlow covered this subject on how cool low temp stats actually cool. You'll see more power at the stock temp cause thats what it was designed for.
aight thanks
