Go Back   Automotive Forums Car Chat > Automotive News Desk
Old 04-23-2004, 09:32 PM
mustangjim88 mustangjim88 is offline
ford engin trouble
my 88 mustang i converted the drums to discs , tremec tko 5 spd. king cobra clutch , short throw, new moter rebuild bored 30 but it keeps popping through the carb , oh ya i made it into carburated . just redid the timing chain but i cant under stand y it is still popping ?
Old 04-25-2004, 07:55 PM
NOVA350SS630hp NOVA350SS630hp is offline
Re: ford engin trouble
popping ? as in back firing, well it could be your carb on my nova the 4 banger was bad so i swaped it out with a edel 750 cfm carb or it could be the intake not to sure tell me more about the problem, just wondering is your stang a cobra or gt anything like that? you might have to change back to TB rather then a carb
Old 05-10-2004, 07:58 PM
gumby84029 gumby84029 is offline
Talking
thats what u get when u buy a ford
Old 05-11-2004, 01:43 AM
Doug Rodrigues Doug Rodrigues is offline
Send a message via MSN to Doug Rodrigues
There's nothing wrong with Fords. I've got more horror stories about GMC products than with Ford products. That's a very objective comment, because for me motor vehicles just get me from point A to point B. They're just another machine.
Old 06-21-2004, 01:51 PM
bshultzrn bshultzrn is offline
Three things that commonly cause backfiring are leaning out, flooding from a stuck float, or timing out of whack. I had the same issue when I shoehorned a BBC into my boat, and I accidently put the timing chain off a tooth, which severely retarded the timing, which could cause the problem. If the timing is advance 4 degrees with a sprocket, or retarded the same way, it's common to be off since the marks that line you up aren't perfect...just a thought. Also, what type of carburetor are you running?..I'd go with a holley 780 myself...
Old 06-26-2004, 10:45 AM
KILLER CAMARO KILLER CAMARO is offline
popping through the carb sounds like a lean condition to me. Turn out your idle screws a little on the metering block, you could also have a 4 corner idle circuit (then turn out all 4) make sure they are all even amounts threaded out. might want to have buddy do this for you, unless you know what i am talking about.
Old 07-18-2004, 08:03 PM
coindex's Avatar
coindex coindex is offline
Send a message via ICQ to coindex Send a message via MSN to coindex Send a message via Yahoo to coindex
usually backfiring through your carb means your mixture is rich NOT lean. The timing is probably off and needs advanced.
Check your float level meter also
Old 07-18-2004, 10:09 PM
WHAT!?!?!? i gotta stick with lean FROM EXPERIENCE. through the muffs=rich through the carb=lean and he was already told about the float level and the timing, either of which could be the problem.
Old 09-28-2004, 10:53 AM
S-10Eater S-10Eater is offline
You guys have covered all i can think of and anybody know good place for supercharger for a 390? (i want it in my 94 Ranger)
heheheheheehehe
______________________________________
94 Ranger
-5spd v6
-Hooker Headers (not on yet)
-Superchip
-Carbon Fiber interior
-Dash,Door Panels, Leather Seats,Diamond Plate Alum. Floor
-Carbon fiber Taillights
-Black Corner lenses
-Clear Headlights
-Swing Away column
-New K&N
Old 10-19-2004, 09:50 PM
ReAl_RaCiNg ReAl_RaCiNg is offline
i know what your problem is, with your popping sound. When you switched over to a carb. in your mustang, you forgot about one important thing. I'm sure it'll make all of the difference. What you did wrong, is you bought a mustang. I mean it's a ford none the less. Go get yourself a chevy, or at least a gm built motor, and everything should work out just fine. If ford is so great, then why did their stock drop to four dollars a share a few months back. enough said.
Old 06-19-2005, 11:43 PM
Rgstab Rgstab is offline
IF YOU KNOW ANYTHING ITS NOT MUCH! Everybody can make a mistake, even God. Thats GM, Gods Mistake.
Man made Ford man can fix FORD.
Check firing order, must match cam. 5.0 & HO are same as 351. 289- 302use a diff. firing order. Dont forget that Real engines (not kids toys) are 1-2-3-4 on the pass. side & 5-6-7-8 on the driver side.
