Old 04-23-2004, 09:06 PM
KrAzYiMpOrTs KrAzYiMpOrTs is offline
Help engine specs-will the SI head fit the HF motor.
Hey guys i have a crx hf and i just raced a 4cyl. 87 toyota pick up and lost badly and i race a 94 civic ex coupe and that car hase v-tec ya i lost but we raced again and i beat him buy a car length but i wanted to no about the HF motor and SI motor. can i put a SI head on the HF motor i think you can or a 1.6 EX head on the HF motor and also i was just thinking if the SI motor and the HF motor is the same thing but I know the HF motor is 8 valve and the SI motor is 16 valve other than that.
Old 04-23-2004, 09:39 PM
travagliante's Avatar
travagliante travagliante is offline
Re: Help engine specs-will the SI head fit the HF motor.
Depends on the year of the hf. Some years have groved pistons as apposed to flat toped ones.
Ok and im going to pull the bullshit card on you beating the 94 ex. and beating it by a car length. Despite the fact that your way lighter, he has 2 times more power(62*2=124) Wait even more than 2 times.
I personally, think swapping cyl. heads its easier to just swap the engine. Thats my .02
Old 04-23-2004, 09:42 PM
90civicracer's Avatar
90civicracer 90civicracer is offline
Send a message via AIM to 90civicracer
Yeah I doubt that your HF motor could beat a 94 ex coupe also, but who knows. If you could find a d16a6 for cheap I'd just go ahead and swap that in (came in the 88-91 crx/hatch si's and 90-91 sedan ex) and that would be a great improvement from 62hp, up to 108hp.
***90 Civic EX 4 Door***
Ace$nyper: yea it did woo woo 4500 posts i should be ashamed *kills self*
90civicracer: haha you killed yourself you got
Ace$nyper: OMFG LOL that might be the funniest thing you EVER posted
bwhahahaha
Old 04-23-2004, 11:16 PM
Yeah go to the junkyard, im SURE you can find something better than what you have, even if its out of like a 92-95 civic cx or even a5th gen dx engine would be a GREAT upgrade compared to what you have.
Just give some yards a call and ask around for prices
Old 04-23-2004, 11:50 PM
thanks for your help guy o yea i did beat the ex he dosent no how to drive the first race was a diffrent driver the second time was him and he was hiting the rev limmiter makes you go faster to so thats y i won but all that matters is that i won it dont matter if he had mis shift or hitting the rev limiter i still won o thaks again for your help you dont have to beleave me but i no he sucks at driving.
Old 04-23-2004, 11:53 PM
oops i mean he thinks hiting the rev limiter makes you go faster sorry about that.
hmmm usually hitting the rev limiter causes a decrease in power. those engines rarely make power over 6-7g.
Old 04-24-2004, 12:31 AM
rosshatch89 rosshatch89 is offline
Send a message via AIM to rosshatch89
yea theres no way you can just swap heads the hf is 8 valve pistons and you'll crash the valves the first time you try to turn it over you could swap piston and go to a high comp piston and then swap out a sohc v-tec and rip people all day and show them the block stamp just my opinion though
Old 04-24-2004, 02:06 AM
lilol89crx lilol89crx is offline
thats what i came across after claying my si head to the hf block. however HT has a write up about using the si head on the hf block to make more hp and tq than the a6. not sure on there surcumstances about that but it didnt work for me.
Old 04-24-2004, 03:16 AM
cybercrx00 cybercrx00 is offline
Send a message via AIM to cybercrx00 Send a message via Yahoo to cybercrx00
Re: Re: Help engine specs-will the SI head fit the HF motor.
The engine out of my '89 HF only had grooves for 2 valves, I would think the other two on the head would hit.
Old 04-24-2004, 03:41 AM
krazyimports, can you use periods and/or punctuation next time so we can read what you're saying a little bit easier?
bwhahahaha
Old 04-24-2004, 04:33 AM
Hey rosshatch89, so i could change my pistons, and put what type of head on the Hf motor, may be the SI or the EX head?
Old 04-24-2004, 12:00 PM
hmm, yes but why. All that work would be easier by just swapping a "junkyard special" engine What year is you hf. I believe that 90-91 are flat topped pistons and 88-89 are groved for 2 valves
Old 04-24-2004, 02:57 PM
My HF is a 91. Why i will just swap heads is beacause i allready have a EX v-tec head laying around, and the crank, and pistons. I have the hole d16 motor but the hole bottom end of the engine is no good.
