Old 04-23-2004, 05:55 PM
BackSpacer BackSpacer is offline
program keyless remote
Hello,
I just got a 1999 Plymouth Grand Voyager that was missing the keyless remotes. I got a new OEM one today off of the internet and I need instructions on how to program it. The owners manual says I need a working one to program the new one. Thats a problem.
Thanks
Old 04-23-2004, 07:37 PM
I see this question asked a lot, but nobody ever replys with an answer. Is this question taboo?
To tell you the truth, I don't even know if this van has keyless entry, but I am assuming it does since most all vehicles since the mid 90's have come with it as a standard option. How can you check to see if it does have it?
Someone please tell me if I can program the keyless fob or do I need to take it to a dealer.
thanks,
Old 04-24-2004, 09:26 AM
hellooooooooo, is anyone out thereeeeeeeeeeeee??????
Old 06-26-2004, 06:06 PM
nomoparknowledge nomoparknowledge is offline
Re: program keyless remote
i have a 97 voyager and bought two more remotes for it took it to the dealer and they programed all 4 remotes for no money. take it to a local dealer and ask best thing to do i say. however you said if you had one working remote you could program it .... ive been searching for at least 2 hours today and havent found anything on programming ifyou already have remotes. do you know where a person could find this info??? thanks
Old 06-26-2004, 06:22 PM
The info about programing your own remotes if you have a working remote is on page 16 of my 1999 voyager manual. I went to my local dodge dealer in wilmington, NC a few weeks ago and they programmed the remote. They didn't do it for free though, they charged me 55.00.
Old 06-26-2004, 07:09 PM
i did not get a manual with my van i will look for one though thanks. on ebay there is a guy who sells remotes for starting at 8 dollars. i bought a pair from him and they worked great.
Old 06-26-2004, 07:24 PM
To program Transmitters:
1. Turn ignition switch to the ON position and leave vehicle in park.
2. Using a previously programmed transmitter, press the UNLOCK button for 5 to 10 seconds. While the UNLOCK button is being pressed, press the PANIC button and release both buttons simultaneously. You will hear a chime sound to signal you that programming on the new transmitter(s) may occur.
3. You may program up to 4 transmitters for your vehicle within a 30 second timed window. Press and release both lock and unlock buttons of a transmitter at the same time;then press any of the buttons once, you will hear a beep when the transmitter has been successfully programmed. A chime will sound when the 30 seconds is over, or if you turn the ignition switch off.
If you do not have a programmed transmitter, contact your dealer for details.
I had to contact the dealer and pay them. If you have a working programmed transmitter you should be OK.
Old 06-26-2004, 07:39 PM
thanks for the info i really appriciated it...
Old 10-07-2004, 06:44 PM
JFlanagan JFlanagan is offline
Re: Re: program keyless remote
Has this procedure worked for anyone? I have a 94 Caravan and it doesn't have the panic button mentioned in the instructions. Any thoughts?
Thanks!
Old 10-07-2004, 10:19 PM
Re: Re: Re: program keyless remote
Thanks!
The info I posted is a copy out of a 1999 plymouth voyager owners manual. I don't know if it is the same for a 94. do a google or buy a manual off of ebay. i bought my 99 manual off of ebay for just a few bucks. the procedure listed only works if you already have a working remote and you are just adding another one. since I didn't have a working one, I had to get the dealer to program it.
Old 10-10-2004, 10:58 AM
arobinso arobinso is offline
My '94 Caravan still had the book when I got it. No mention in the owners manual how to program the remotes. Other than telling you how to use them, the only related detail in the book is that the horn chirp can be turned off by dealer programming. So, probably need to go to the dealer unless someone else has access to the Mopar service books.
Old 12-27-2004, 04:49 PM
admin12 admin12 is offline
Thanks!
I have to said yes, the procedure is totally corect and its work, i have a 1999 Grand Caravan.. and i programmed with the instrucions mencioned here... thanks to the guy that did that..
Thanks
Old 01-01-2005, 01:57 PM
RM-TECH RM-TECH is offline
Hello,
Thanks
I've been in the same boat befor with a '94 and a '96 Caravan. Hopefully this information will help you. You can disregard the detailed descriptions of the remote transmitters that this bulletin refers to and skip down to the actual instructions at the bottom. The procedure involving grounding the green wire worked well in my '96
Regards
Date: Mar. 25, 2002
Models: 1999 - 2002 (BR/BE, DR) Ram Truck
1999 - 2002 (AB) Ram Van/Wagon
1999 - 2002 (AN) Dakota
1999 - 2002 (BR/BE)Ram Pickup
1999 - 2009 (DN) Durango
2002 (DR) Ram Pickup
2001 - 2002 (JR) Sebring Sedan/Stratus Sedan/Sebring Convertible
2002 (KJ) Liberty
1999 - 2002 (LH) Concorde/Intrepid/LHS1300M
1999 - 2000 (NS) Town & Country/Caravan/Voyager
1999 - 2002 (PL) Neon
1999 - 2002 (PR) Prowler
2001 - 2002 (PT) PT Cruiser
2001 - 2002 (RS) Town & Country/Caravan/Voyager
1999 - 2002 (WJ) Grand Cherokee
1999 - 2001 (XJ) Cherokee
Discussion:
A Remote Keyless Entry (RKE) Programming Procedures Card (Publication No. 81-170-00011) is being provided with this Technical Service Bulletin to simplify RKE transmitter programming on 1999 - 2002 North American vehicles. Additional copies of the RKE publication, 81-170-00011 (Fig. 1), can be ordered from DDS Distribution Services, LTD. Their number is 1-300-890-4038.
NOTE: THE RECENTLY RELEASED MILLER SPECIAL TOOL, "RF DETECTOR NO. 9001", SHOULD BE USED TO DETERMINE IF THE TRANSMITTER IS WORKING BEFORE BEGINNING PROGRAMMING PROCEDURES. THE RF DETECTOR INDICATES IF THE TRANSMITTER IS WORKING, NOT IF IT IS PROGRAMMED TO A VEHICLE.
DaimlerChrysler North American Remote Keyless Entry Programming Procedure
AB
56045191AD*
W/WO
RAMS HEAD WJ (GRY)
58036860AD* WJ, XJ (BLK)
56038?59AD*
JR, LH, KJ
04602260AA*
RS
645??797AB* PL (GRY)
0475???8AE*
LH
0460??6?AC*
(PRE 01 ONLY) DR, NS, RS
AN, DN
0468646?AC*
PT
04571641AD*
W/WO
PENTASTAR
AN, DN, BR, BE
56045497AC*
W/WO
RAMS HEAD*
(99-00 only)
*Note: these part numbers were very hard to read on my copy of the bulletin.
They may not be correct. If you need to replace a FOB, see your dealer for the correct numbers.
RKE Programming Procedure - Letter Indicates Programming Method
Vehicle
Name Current
Platform 1999
Programming
Method 2000
Programming
Method 2001
Programming
Method 2002
Programming
Method
Sebring
Stratus JR - - A or C A or C
Concord
Intrepid
LHS
300M LH A or C A or C - -
Caravan/
Voyager
T&C NS - - A or C
(3BTN) & (5BTN) A or C
(3BTN) & (6BTN)
Neon PL B or C B or C B or C B or C
Prowler PR A or C A or C A or C A or C
PT Cruiser PT - B or C B or C B or C
Ram Van AB C or D C or D C or D C or D
Durango
& Dakota AN/DN B or C B or C A or C A or C
Ram Truck BR/BE B or C B or C B or C B or C
Ram Truck
1500 DR - - - A or C
Jeep
Liberty KJ - - - A or C
Grand
Cherokee WJ C
(BL)&(GRY) C
(BL)&(GRY) C
(BL)&(GRY) C
(BL)&(GRY)
Jeep
Cherokee XJ C C C C
DO Reprogram all of the vehicles transmitters at the same time.
DO NOT
Reprogram if replacing a transmitter battery,
If any of the transmitter buttons ???? (illegible),
For reduced range performance
NOTE: If equipped with VTSS, the system must be disarmed and/or unlocked to enter program mode.
Warning: Simultaneous programming of multiple vehicles should be avoided as any transmitter
activated within 30 meters (100 feet) can get programmed and may result in cross-vehicle programming.
DaimierChrysler North American Remote Keyless Entry Programming procedures
NOTE: PLEASE READ INSTRUCTIONS FULLY BEFORE ATTEMPTING TO PROGRAM TRANSMITTERS.
Program Method A (Customer Program Method)
1. Press (LOCK) button 5 times at 2 second Intervals to resynchronize transmitter, Attempt to function transmitter, If working as designed discontinue programming.
2. Turn ignition to run position, (Allow Ignition chimes to stop).
3. Using any original (working )transmitter, press the [UNLOCK] button for 4 to 10 seconds.
4. Within the specified 4 to l0 seconds, continue pressing the [UNLOCK] button and press the [PANIC] button for 1 second and release both buttons (AN/DN release either button first). A chime will sound to indicate that the transmitter programming mode has been entered (allow 3 seconds for chime to sound).
5. Press [LOCK] and [UNLOCK] buttons simultaneously for 1 second and release (a short chime will sound for AN/DN).
6. Press and release any button an the same transmitter and a chime will sound after successfully programming the transmitter (locks will cycle for AN/DN).
NOTE.- (FOR DR ONLY) A CHIME WILL NOT SOUND ON STEP #6 FOR THE FIRST TRANSMITTER PROGRAMMED, BUT WILL SOUND UPON PROGRAMMING THE SECOND TRANSMITTER.
7. Repeat steps 5 through 6 to program additional transmitters.
8. Turn ignition to OF:F position. Transmitter programming mode will discontinue after 60 seconds (30 seconds for AN/DN and RS). (All transmitter programming must be completed within time specified).
Program Method B (Customer Program Method)
1. Press [LOCK] button 5 times at 2 second intervals to resynchronize transmitter. Attempt to function transmitter, it working as designed discontinue programming.
2. Turn ignition to the run position (Allow Ignition chimes to stop).
3. Using original transmitter, press and hold the [UNLOCK] button on the transmitter for between 4 and 10 seconds.
4. Continue to hold the [UNLOCK[ button and press the [PANIC] button. A chime will sound to indicate that the transmitter programming mode has been entered (Allow 3 seconds for chime to sound).
5. Press a button on all transmitters to be programmed into the system including any previously programmed transmitters; a chime will sound when each transmitter has been programmed.
6. Turn the ignition to OFF position to exit the transmitter programming mode.
Program Method C (Dealer Program Method) *Can be used for any type transmitter.
1. Press [LOCK] button 5 times at 2 second intervals to resynchronize transmitter. Attempt to function transmitter, if Working as designed discontinue programming.
2. Turn ignition to the run position (Allow ignition chimes to stop).
3. Plug DRBIII to vehicle's 16-way data link connector.
4. Follow Service Manual and DRBIII Instructions to program transmitters.
Program Method D (For use with AB vehicles not equipped with VTSS only)
1. Locate the dark green program enable wire connected to pin #1 of the 16-way data link connector under the left side Of the Instrument panel.
2. Connect the program enable more terminal to a good ground.
3. Insert the key into the ignition and turn the ignition switch to the ON position. The power locks will cycle (Lock and Unlock) indicating that program mode has been entered.
4. Using the transmitter to be programmed, press either [LOCK] or [UNLOCK]. The power locks will cycle indicating the transmitter has been programmed successfully.
5. Repeat step 4 to program additional transmitter.
6. Disconnect the program enable wire from ground to exit program mode.
7. Turn the ignition to the OFF position and remove the key.
NOTE: REFER TO DAIMLERCHRYSLER MD82 SYSTEM OR PARTS DEPARTMENT TO OBTAIN THE CORRECT PART NUMBER AND REVISION FOR SPECIFIED VEHICLE.
Policy: Information Only
Old 01-01-2005, 02:06 PM
Thanks!
Your '94 remote has a dedicated "rear door unlock" button. The rear door open button (black) on your '94 remote became the "red" panic button on '95 and later cars. The 'unlock" button now opens all doors including the rear door. The transmitter is the same, other than the red button. You can use an earlier "black" transmiter on newer cars. By simply programming them to the car. The only problem is that anytime you try to "open" the rear door, the alarm goes on.
Regards
Old 01-02-2005, 03:26 PM
erosol erosol is offline
I don't even know why they have the site, nobody seems to ever write back, maybe because they'll all stupid and don't know anything.
I have a 1996 Caravan and had to get the first one done at the dealer, at no charge, lucky. They have to hook up the hand held computer to set the remote. After you have the first one, you can do the rest on your own. Good luck.
