Old 04-23-2004, 05:45 PM
rocket99 rocket99 is offline
1999 suburban keyless entry
I have a 99suburban and the keyless entry has never honked the horn when I lock it. Is it supposed to? How do you program this feature?
I am half deaf and can't hear the click when the doors lock. Thanks for any info.
Old 04-27-2004, 05:39 PM
CalessaSSracer CalessaSSracer is offline
Re: 1999 suburban keyless entry
does your HORN work?
Old 04-27-2004, 07:07 PM
gearhead53704 gearhead53704 is offline
Forgive me if I'm stating the obvious but, the first time the lock button on your keyless activates the locks the horn does not honk. If you want it to honk you have to activate the locks a second time for the horn to honk. At least that is the way it works on my 98 Sub and I assume thats how it is supposed to work...... Be nice if my keyless was more consistant in working but thats a whole other discussion.....
Old 04-27-2004, 08:18 PM
yup pressing it twice "honks" it !
but whats the honking for anyways ? is that the alarm?
Old 04-27-2004, 09:11 PM
my horn works. The second, third etc attempts only click the locks that are already locked. The horn blows on the second push of the button to assure you that the door is locked.
Old 04-27-2004, 10:07 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
I believe that's the only way the OEM units can be set up. I know many of the aftermarket keyless entries can be changed to honk each time you press the button.
Old 05-17-2004, 02:32 AM
Firetamer7 Firetamer7 is offline
Send a message via AIM to Firetamer7
does anyone know the programming procedure for the 99 suburban key FOB, and how many remotes can be programmed to the factory system.
Old 05-17-2004, 03:16 AM
never mind.... found them on the next page by GMMERLIN
here is what he posted just to repeat:
When reprogramming the remote control door lock reciever, All transmitters must be programmed at this time in order for the transmitters to operate the vehicle. Transmitters not programed at this time will not work and the procedure will have to be redone with all the transmitters.
Ground pin 4 to pin 8 of the data link connector (DLC). The receiver will respond by locking and unlocking the doors, and activating the liftgate window release (if equipped) within 2 seconds.
Press and hold the LOCK and UNLOCK buttons simultaneously on the first transmitter to be programmed until the locks cycle (approximately 10 seconds).
Repeat step 2 for up to four total transmitters to be programmed (if available). The receiver will respond by locking and unlocking the doors and activating the liftgate window release (if equipped) within 2 seconds.
Remove the ground applied to the DLC.
Lock and unlock the doors in order to verify the transmitter operation.
Activate the rear window release in order to verify the transmitter operation.
Old 05-17-2004, 03:53 AM
To rockett99 here is an interesting note I just read. Haven't tested it on mine yet but it pertains to you. In regards to programming the
Remote (FOB) ....................
Transmitter Programming
If they key is in the ON position during the programming procedure, the horn chirp will be disabled, if the key is in the OFF position, the horn chirp will be enabled. The horn will chirp when the lock button is pressed two times.
