Old 04-23-2004, 05:34 PM
drahcir drahcir is offline
Odyssey cabin/pollen filter
Owner's Manual says to R/R cabin/pollen filter every 30K. They do not give any info on where it is or how to do it but "take it to the dealer". Does anyone know where this filter is and how to replace it? Thanks
Old 08-29-2004, 10:04 PM
cablepower_9 cablepower_9 is offline
odyssey pollen filter location
I believe the pollen filter is behind the glove box. Take the glove box out, remove filter, blow clean and replace.
Old 08-13-2005, 10:15 AM
Tonyb416 Tonyb416 is offline
Re: odyssey pollen filter location
Behind the glove box or is the filter underneath the glove box? When I look underneath the glove box I see a plastic housing tray that's attached to the dash with 2 bolts in the back (8 mm) and two screws slightly closer to the front. There is a rounded plastic piece closer to the front of this housing/tray unit. Is this what I have to remove?
How do you remove the glove box? Do I need to remove the glove box to get to the two screws and the plastic piece that secures the filter?
Thanks for your help and advice.
--Tony
Old 11-19-2005, 02:27 PM
Kabbi Kabbi is offline
Unhappy Re: Re: odyssey pollen filter location
Help! I got on today with the same question. How do you get the glove box out?? In my other car it's easy, but it's not obvious on the Odyssey.
