Go Back   Automotive Forums Car Chat > Volkswagen > Beetle - New/New Beetle Convertible
Old 04-23-2004, 05:12 PM
KRMelton KRMelton is offline
'79 Super Beetle speedometer problem
Hello Everyone,
I'm a newbie here, so bear with me. I have '79 Super Beetle convertible that looks and runs great -- except for one problem. On a recent trip of about 1,000 miles the speedometer needle started bouncing around and a horrific noise started coming from the front trunk compartment. I pulled over and traced the speedometer cable from the left front wheel hub to a where it attached small black box in the trunk. Then the cable exits the box and continues to the speedometer. I believe the noise is coming from this little black box but none of the books I have reference this box in speedometer cable replacement discussions. Has anyone seen this box before? What does it do?
Thanks,
Kenny
Old 04-25-2004, 12:39 PM
boschmann boschmann is offline
Re: '79 Super Beetle speedometer problem
It's a counter box for the service light in the speedo. Usually it's the cable that makes noise, but the boxes can also. You can remove the clip & cap at the wheel & spin the cable with a drill (in reverse) to isolate the noise better. If it is the box they are difficult to find new. You can probably find one from a older Rabbit (A1) or Golf/Jetta (A2) that will work.
Old 06-25-2004, 04:43 PM
bluebug's Avatar
bluebug bluebug is offline
The speedo head can be disassembled and repaired. If you go to superbeetles.com they have a resoration corner link and step by step instructions with pictures. Clark
