Old 04-23-2004, 05:07 PM
dirtydx dirtydx is offline
Need Advice on Alternator
Hey.. just got my car back on the road.. its been sitting for 6 months, only driven once or twice a month.
anyways.. the alternator was brand new before i took the car off the road. it has 100kms on it at the max. Today, while starting the car, downshifting.... whatever, when the engine accelerates(from low rpm), the alternator squeals like a pig.. kind of embarrasing with stop and go driving. i'm guessing the alternator is partially siezed up...
any ideas of how to get it free again?? would i be stupid to spray lubricant on it??
thanks for the help
"I just threw away a lifetime of guilt-free sex and floor seats to every sporting event in Madison Square Garden. So, please, a little respect, for I am Costanza, Lord of the Idiots."
Old 04-23-2004, 06:21 PM
V-K V-K is offline
Send a message via AIM to V-K
Re: Need Advice on Alternator
Sure the belt isn't just loose?
Old 04-23-2004, 06:27 PM
hmm never thought of it that way, thanks i'll check it out.
Old 04-23-2004, 06:35 PM
V-K V-K is offline
I had that issue with mine just a few weeks ago. The bottom bolt kicked out on its own (How that happened I'll never know, things a biatch to get off).
Old 04-23-2004, 10:23 PM
yeah u were right.. thanx
about the bottom bolt.. if ya take the wheel off, and push the mudgard to the side, you can get a socket on it.. a lot easier than reaching a wrench down in there..
Old 04-23-2004, 10:25 PM
V-K V-K is offline
Its not getting the wrench in there I have the issue with, its that the bolt seemed to big for the hole, and I had to always hammer the thing out. :P
Old 04-23-2004, 11:33 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Re: Re: Need Advice on Alternator
You can try what I did after I took mine out. I cleaned the bolt with a bench grinder equipped with a wire brush head and greased it up before I put it back in. (I just realized my post sounds like an S and M porn.....) GL
Old 04-24-2004, 12:38 AM
rosshatch89 rosshatch89 is offline
Send a message via AIM to rosshatch89
yea wierd as it may sound my alternator was a new one and it was making a grinding noise but the belt was tight so i wasnt worried well i found out later the bottom bolt had fallin out somehow and the thing was in a constant bind but yea if your belts tight and its still squealing then just spray it down with wd-40 or whatever that should stop it and altenators arent very sensitive so you cant hurt it
Old 04-24-2004, 07:09 PM
89stdzc 89stdzc is offline
Send a message via AIM to 89stdzc
speaking of that... i did a little trip aprox. 200 miles or so. the top bolt Broke off inside of the alt. all i had was zip ties a few diff. standard wrenches and a file..... i tried the zip ties.... it didn't work...for long... so while broke down on the side of the highway guess what i find. a bolt that fitted perfectly into the hole but it the broken bolt was still in there... i used the file to help it out... then used the file to grind down the standard wrench to fit the bolt and i put it in.... i've never changed that bolt since......
gay story but never say you're stuck and pray to god some other piece breaks down cause a bolt from their car fell off.
Old 04-24-2004, 10:01 PM
V-K V-K is offline
Zip ties are a MUST HAVE in anyones glove box! lol
I was traveling down the highway once, and one of the rubber loops that holds the exhaust up broke. Had the muffler replaced not but a few weeks before that and they guy said the mounts where NOT covered under warranty. Zip ties held that bad boy up for about 10,000 miles before I actually had it replaced
