Old 04-23-2004, 03:01 PM
timssail timssail is offline
Angry another 98 blazer with a dead battery 3days
I have the same problem with a 98 BLZ. replaced the starter Which was bad. "I am not sure about that either". Anyway the same thing goes on with the battery thing. The battery is brand new and the dash wiring was worked on at the dealership before we bought it. Turned off the override dash button, still no change. Alternater was tested also. Stumped! this is the LS Blazer Electric everything.
Old 06-12-2004, 09:47 PM
blazerjake blazerjake is offline
Send a message via AIM to blazerjake
dying battery
If you have the factory installed delco radio, try removing it for a few days and see if that fixes the problem.. I had the same problem on my LT and I found the memory on the radio was drawing TOO much power when ignition was off.. Common problem! Hope it helps ya!
Old 06-21-2004, 10:55 PM
chewygoo1 chewygoo1 is offline
Re: another 98 blazer with a dead battery 3days
I'll second that on the factory radio. The '95 Blazer I sold would go dead after three days and traced it down to the Delco radio.
Old 06-22-2004, 07:04 AM
pernicev's Avatar
pernicev pernicev is offline
Battery
Your "new" battery could quite possibly be bad, not an unlikely scenario. It may even be a refurbished battery that was sold as a new battery.
Also, since you mentioned the wiring had been tinkered with (dealer or not), this could be shorting the battery somewhere, causing discharge.
Old 06-22-2004, 09:12 AM
countryboy countryboy is offline
had one the light would stay on under the hood and run the batt.down did not find it till i was walking out side after dark
Old 08-11-2004, 02:41 PM
hvollstedt hvollstedt is offline
Send a message via MSN to hvollstedt Send a message via Yahoo to hvollstedt
I had the same problem, turned out when I leave the keys in it as I always do there is a position where you think that it is off, it is not and it drains the battery, also I started unplugging anything in the cigarette lighters and got a new battery, has worked ever since, till my alternator went out on Sat now replaced that and everything is in order, so far (knock on wood)
Old 08-12-2004, 09:53 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Some quick questions:
1.) Did you charge your new battery FULLY before you installed it into the truck.
2.) Did you check for some shorts or dead grounds?
