Old 04-23-2004, 03:00 PM
gonecrazy97 gonecrazy97 is offline
Acceleration problems
I have a '99 F-150, 6 cyl, ext cab, 87,000 miles. About a year ago, I started to have problems with acceleration. At first it just hesitated, then it completely lost power on the highway one day. The engine didn't die, it just wouldn't accelerate. At that time, I had the fuel injectors cleaned, fuel filter and pump replaced, and regular maint like spark plug and wire change and O2 sensors replaced. The truck ran fine for a month then started same prob again. Second visit, the mech said the injectors were caked again, filter was gross. He changed injectors, filter, and pump again. He also took out the tank and cleaned it. After about $1k the truck ran fine....for a year. Last month (March) started to have same problems again! Cleaned fuel injectors, changed fuel filter and pump again, also changed plugs and wires again. Ran fine for another month...It's in the shop again (April) for same problem!!!! Someone please help.
Old 04-23-2004, 11:27 PM
97chevyman's Avatar
97chevyman 97chevyman is offline
Re: Acceleration problems
get your gas somewhere else, and add some antifunicide to your gas.
Old 04-24-2004, 11:24 AM
We've moved to another state since probs last year. Are there that many stations with bad gas? Also, where can I get this antifungicide and what will it do?
Old 04-24-2004, 11:32 AM
cogger cogger is offline
Send a message via ICQ to cogger
Are you buying the same brand of gas?
Old 04-25-2004, 12:08 PM
We've always used reg unleaded. The mech that has it now says that he thinks it has something to do with the transmission. I don't think I buy that. According to the repair manual, it says its all in the fuel system.
Old 04-25-2004, 12:14 PM
not type> what brand?? Gulf, Texaco, etc....
Old 04-26-2004, 02:33 PM
flareside99 flareside99 is offline
Don't know if this helps, but a common problem of the 4.2L engines in the '99 F-150's is the restriction of the EGR passages in the lower intake manifold.
Old 04-26-2004, 06:03 PM
We usually fill it at the station on our military base, otherwise we try to use Mobil or Amoco. How common of a problem is it? Do the symptoms I described sound like that could be it? Would it re-occur? Thanks for your time everyone.
Old 06-08-2004, 04:27 PM
FghtinIrshNvrDie FghtinIrshNvrDie is offline
Send a message via AIM to FghtinIrshNvrDie
I know it sounds dumb, but it's probably an electronic tranny if it's a 1999, so do something simple as check the fuse for your tranny, or have someone qualified look at all that wiring. good luck with it
Old 06-11-2004, 09:01 AM
97chevyman's Avatar
ok, wiring will not effect the injectors in caking up. Now low fuel flow would possibly, check you fuel pressure and see if that is normal.
2000 ford F-250 4x4 CC auto
1978 F150 4x4, 6 inch lift painted john deere green
Old 06-22-2004, 05:54 PM
pete54ford pete54ford is offline
Send a message via Yahoo to pete54ford
Sell it. Buy a Pinto.
Old 08-07-2004, 01:13 AM
JS942 JS942 is offline
Have you checked your trottle Position Sensor(TPS). After all the work you had done to it they probably have. I had almost the same problem on my 92 F150. I also was told to flush my injectors and so on. A $40.00 part fixed it.
