I need to remove my 95 Civic Ex 1.6L ECU. Can anyone help with a walkthrough or some tips and pointers?
I have never done it on that model year but I am sure its the same as mine.
Its under the passenger side. Its located near the passenger side door closer to the firewall behind a panel. There might be a screw on that panel, remove it and then pull off the panel. The rest is self explanitory. There is a series of 10mm bolts that hold the ECU on with brackets. Remove them and then disconnect the wiring harnesses. |
You take off the kicker panel, loosen some mounting screws, and unplug it.
