Go Back   Automotive Forums Car Chat > Ford > Contour
Old 04-23-2004, 10:36 AM
killer_cr80r killer_cr80r is offline
1995 Ford contour GL tranny slip drive to overdrive please look...
Well my transmission slips from drive to overdrive alot sometimes it doesn't and sometimes it does... the rest of it dont slip at all how long before my car is completely out i can drive without overdrive but its more expensive
Btw the tranny doesn't slip from drive to overdrive when i have the gas pushed to the floor then it shifts fine @ 102 mph
Old 04-24-2004, 03:50 AM
RexNfx400's Avatar
RexNfx400 RexNfx400 is offline
Re: 1995 Ford contour GL tranny slip drive to overdrive please look...
How many miles on the car?
Old 04-26-2004, 10:31 AM
Re: Re: 1995 Ford contour GL tranny slip drive to overdrive please look...
143k
close 2 144k
Old 04-26-2004, 11:50 AM
RexNfx400's Avatar
Im' sure with that many miles, its already been rebuilt. And has had the updated parts installed. It seems strange to say its slips only in OD. Due to it really shouldn't just slip in 4th gear(internally). It should have problems in other gears as well. By tranny design.
Couple questions for you:
1. When it makes the transition to 4th does the engine RPMs race up but don't seem to pull the car? Goes to like nuetral
2. Do you get a bucking/jerking feeling?
Old 04-27-2004, 10:35 AM
1.Yes, The rpms jump when it goes into 4th not to much but sometimes its worse than others and when i turn my od off and on with the button it wont slip its only when i accelerate and let of so it goes into overdrive.....not totally let off but move my foot back on the gas pedal
2.No
Old 05-04-2004, 10:57 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
I would think its the belt slipping not the tranny.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
