Old 04-23-2004, 09:08 AM
Alphid Alphid is offline
Water leaking in the Front Passanger door
Hello-
Another Questions for your guys.
Recently there has been some water leaking into my car from outside and going onto the front passanger floor. I am not sure exactly were it is coming in but I am almost sure that it is not coming in from the rubber sealant between the door and the body. The questions that I have are:
Has this happened to anyone else? How did you fix/diagnosis it? What kind of water repellant can you use on the car to avoid any damage to it?
my car is an 01 4 door alero, 3.4 l
Thanks,
Old 04-24-2004, 01:33 AM
JTrujillo86 JTrujillo86 is offline
Re: Water leaking in the Front Passanger door
This is a common issue with pre 2002 Aleros. I can remember what exactly causes the problem, but do a little board-surfing on the Alero threads, and you'll find something. It's been talked about a few times here.
- Jeremy
