Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 04-23-2004, 08:44 AM
99 FRUSTRATED JEEP 99 FRUSTRATED JEEP is offline
Question Rear end sways a lot.
I have a 2x2 ranger 98 and when I go over bumps the rear ends seems to sway a lot? Is this normal or is something going out on it? The shocks seem to be good and I'm stumped!!! THX
Old 04-23-2004, 11:44 PM
97chevyman's Avatar
97chevyman 97chevyman is offline
Re: Rear end sways a lot.
sounds like bad shocks.
Old 04-24-2004, 09:37 PM
TheRangerOfDanger TheRangerOfDanger is offline
how much does it sway... all pickups sway a little more than cars when you hit a bump on the road - it has been the case with the two rangers i've had... and they both had pretty tight suspensions
If it moves and it shouldn't, use duct tape.
If it doesn't move and it should, use WD40.
Old 04-27-2004, 10:15 PM
2000mudder's Avatar
2000mudder 2000mudder is offline
rangers have very soft suspentions.this is common.new quality gas shocks will help some.
Old 04-28-2004, 08:10 AM
do you put alot of weight in the bed?
if so, you may want to make sure that your leaf springs aren't sagging.
