Old 04-23-2004, 06:20 AM
healthmgr healthmgr is offline
cv axle assembly R&R
Any tips on removing a cv axle assembly out of a 93 accord ex? Started last nite but got hung up on lower control arm connection to ball joint. It seems I meet need a puller for this fitting. Also don't want to remove more than needed....I am replacing axle and both inner and outer joints at same time as a unit. Any help appreciated greatly........Later
Old 04-26-2004, 12:50 AM
aluminumpork aluminumpork is offline
Re: cv axle assembly R&R
I used a puller on my first replace, but on my second I found that giving the arm itself a good whacking will release it. I just used a brass rod and a 2 pound hammer. Someone will probably say that's a bad thing to do, but it worked fine for me and I didn't have hassle with a damn puller and the little flanges that you're supposed to use on the lower control arm.
Old 04-26-2004, 04:01 PM
skubydobdo skubydobdo is offline
Yeah pullers are cheap to rent form like Pep Boys if you don't have access to one already.
