Old 04-23-2004, 01:22 AM
aznbmxxxer aznbmxxxer is offline
Send a message via AIM to aznbmxxxer
how fast?
how fast with a 01 civic si with cold air intake, 70mm tb, intake manifold, type r cam intake and exhasut, no cat, dc 4-1 headers be? a friend wants to do all that, and hed rather go all motor then turbo, what else could he do to make all motor faster?
Old 04-23-2004, 02:06 AM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
pistons
Old 04-23-2004, 03:30 AM
ricerboy8627 ricerboy8627 is offline
Re: how fast?
Originally Posted by SiGNAL748
pistons
exactly that would be best to do hi comp pistons but if he doesnt want to tear apart the engine then there are more bolt ons like cam gears. pulleys, upgrade cpu, uprgrade fuel system and gut the interior. Im sure there is more but the best way to go NA is raise the compression, im not sure of what kind of ratios to use but ive heard of racers using 13 or 14:1 ratios and im sure higher but dont take my word im not sure what would be safe.
My 97 eclipse RS is for sale check it out! http://www.autotrader.com/fyc/vdp.jsp?car_id=161384093
Old 04-26-2004, 04:05 PM
Tranzlogic Tranzlogic is offline
Send a message via AIM to Tranzlogic
Re: how fast?
a 14:1 car is retarted for street use..and say fare well to pump gas !!!! and cam gears are gonna be a waste of money with type R cams in my book. I say go the next step up with a set of JUN stage 1, Crower Street 1's or Toda Spec A's and then a set of AEM Tru Time cam gears to back it up....set your timing ahead a degree or 2 and lower your Vtec engaugment with rather a chipped ecu or perhaps a good controller, also throw in a quick shift kit B&M race or something with a real quick throw. You dont have to pay big money and do major mods to get " quick " ! If you want massize HP numbers then your gonna have to go boost, but who cares about numbers unless your strip ! Day to day driving with these mods and you will be very happy with your outcome ! but further down the line a set of 11:5:1 pistons or just a set of type r pistons would get that compression up and give you alot more pull but dont go higher than that !
Old 04-26-2004, 04:13 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: Re: how fast?
You're book sucks. Almost every single set of ITR/CTR cams I have seen benefited from 2-3 degrees of advance.
