Old 04-22-2004, 10:20 PM
Dr Juice Dr Juice is offline
Send a message via AIM to Dr Juice Send a message via MSN to Dr Juice
how do i remove climate contols
Well i need to take out the climate control center if you will. I need to get back there and change out a light cuase its burnt out. Does anyone know how to get it out?
Old 05-10-2004, 05:56 PM
wheel1856's Avatar
wheel1856 wheel1856 is offline
Send a message via AIM to wheel1856
take out the center console.
underneath the climate controls there are 4 brass screws holding it in place : 3 up front, 1 further back. remove them
undo the 2 wiring harnesses from the back, the green one's a bitch, you'll probably need to take out the radio and top dash vent to get to some of the stuff.
unhook the vent wire
remove the controls, the lights are inside the control panel which comes apart fairly easy, but be gently, the plastic snaps easy too.
spend 13 bucks on a Haynes manual at autozone, its all in there. you need bulb code 74.
"Why yes, this is a GS-R."
