Old 04-22-2004, 09:06 PM
superman0604 superman0604 is offline
Firewall
I have a 97 GMC Sierra and need to find a place to run the power cord to the battery, and I can not find a place to run it through the firewall.
Old 04-22-2004, 11:35 PM
burly burly is offline
Re: Firewall
You may have to drill a hole and place a rubber grommet it in. Thats what I had to do in my 2003 Malibu.
Car: 2003 Malibu (Base)
Modifications: KC Fog lamps, autodimming rearview mirror w/ compass&temperature, window tinting, rear speakers, front speakers, sub, synthetic ATF & aux tranny cooler.
Future modications: Dynamat interior, alloy wheels & new tires, intake, exhaust & intake manifold???
Old 04-23-2004, 09:41 PM
COchevySS COchevySS is offline
Re: Firewall
I think drilling a hole is your best bet. Depending on what gauge wire you are using there may not be an existing hole it can fit through.
Old 04-23-2004, 10:07 PM
Where would be the best place to drill a hole?
Old 04-23-2004, 11:41 PM
Re: Firewall
Werever the wire needs to go and somewere you wont be able to see it from the inside. Make sure you use a grommet.
Old 04-26-2004, 09:37 PM
Lunchybox Lunchybox is offline
Re: Firewall
i thought i had the same prob with my 99 dakota, but there was this rubber casing in the firewall right next to the steering column, about 5 inches away, i kind of stabbed a hole big enough for the cord to fit through, there may be something like that with yours
Old 04-26-2004, 09:42 PM
jweb1369 jweb1369 is offline
Re: Firewall
I would drill it by the pedals.. so u can have the wires going from around the side of the door.
Old 04-26-2004, 09:44 PM
Re: Firewall
not to close to the pedals, to keep out of your feets way.
