Old 04-22-2004, 08:34 PM
redlineclipse redlineclipse is offline
Second Part: Help! Please Again
Ok, here's progress. I tested some simple things. The car cranks with the starting fluid and runs until it burns out. However, one time the car actually cranked and would run. I drove it a little to make sure everything was ok. When I parked it and turned it off, it went back to the same ol rararrrarrarr. Does this mean that the pump is just on the brink of failing completely, or is there a possibility that it's a fuel pump relay (located right under the hood right?)? I will change the filter, but the filter by itself wouldn't have the same effect right? Also, where exactly is the fuel filter on an eclipse. I know where the pump is but I haven't even had a chance to look for the filter. Thanks
jason
Old 04-22-2004, 11:30 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
yes the filter can have a big affect on the car... i'd say check that right away! what year is your car... so we know where to tell you to check!
Old 04-22-2004, 11:48 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: Second Part: Help! Please Again
96 I win.
Old 04-22-2004, 11:53 PM
Re: Re: Second Part: Help! Please Again
Originally Posted by JoeWagon
96 I win.
Exact. It's a 96 RS 2.0 DOHC
Old 04-23-2004, 12:10 AM
JoeWagon's Avatar
Banned
I think its under the battery...
Old 04-23-2004, 01:37 AM
accessible best from under the car or by taking out the battery and working from the top. Is it under the battery or on the frame under the car?
Thanks for your help
Old 04-23-2004, 11:06 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
If it is the same as a GS-t have fun. You have to remove the battery and the mounting plate the battery sits on. The fuel filter is bolted to the firewall. You will do best to get it from the top (at least that's how I did it). If it is anything like the one I did the fittings are a BITCH to break loose. Be careful with the fittings, if I remember correctly the bottom one is a hardline and the top one is a softline. So if you remove the top fitting first be careful you don't snap the hardline while you are busting you knuckles trying to get it off. All in all, I think it took about an hour or so to do it. Enjoy. Let us know how you make out.
Old 04-23-2004, 11:18 AM
EclipseRST's Avatar
Banned
no its not... the turbo and non turbo cars are totally different, opposite side of the car!
Old 04-23-2004, 11:53 AM
Cool....maybe his will be easier than mine!
Old 04-23-2004, 11:57 AM
It wouldn't be like the gst would it. I thought that the engines and everything else was different for the gst?
Old 04-23-2004, 01:48 PM
I know that the motors are different but I thought maybe they piped in the fuel the same way. Anyhow....if you look above EclipseRST said that it is on the other side. So I would look on the driver's side of the firewall (since mine is on the passinger's side)
Old 04-23-2004, 01:53 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Fuel filter on a NT 96+ is under the passenger side near the rear wheel (or was it the front) I don't remember.
On a 95 NT it is bolted to the firewall.
For Sale 98 Eclipse GS, 5 spd
