Old 04-22-2004, 05:53 PM
jeepincooch jeepincooch is offline
Send a message via Yahoo to jeepincooch
Unhappy Won't hold oil pressure
I have An 01' cherokee with the 4.0 liter engine. When the engine is cold it will hold 40 psi of oil pressure. As it warms up the oil pressure drops and at an idle at opperating temp the pressure is no existant. if ne one has aclue please help thnx
Old 04-22-2004, 07:10 PM
Dale Aeppli Dale Aeppli is offline
Re: Won't hold oil pressure
HI, IF YOU EMAIL ME AT [email protected]----i'll send you information on checking the senders out can't send thru the forum
DALE [email protected]
Old 04-22-2004, 10:08 PM
old 300 old 300 is offline
I guess that there is a lot of people with the same problems. I too have trouble with my 98. I replaced the sender and it was ok for a couple thousand miles and then back to very little pressure at idle. I bought a cheap guage at the auto store and hooked it up ( manual type) and I was running 40-45 at approx. 2000 rpm hot and 25 at idle. My dash guage was up and down while driving and very low at idle, I have read lots of letters in these types of forums. I wonder whats up. If anyone has an idea let us know.
Old 05-03-2004, 02:54 PM
tgrudzin tgrudzin is offline
same issues, I just lift the hood and jiggle the connectors at the sender. Works fine. 151K miles
Old 07-02-2004, 06:43 PM
debb718 debb718 is offline
warn out cam shaft bearings and cam shaft
would cause low oil pressure
i have the same problem with my 87 4.0 Inline 6 the camshaft is availible thur autozone and runs about 80 dollars
