Old 04-22-2004, 04:26 PM
tegger tegger is offline
Send a message via Yahoo to tegger
93 Park Aveune 'intermittently' turn signal
My turn signals flash very slow or stop for a second or two. Is there a flasher that needs to be replace? If so, where? Thanks
Old 04-23-2004, 10:24 AM
rotaran's Avatar
rotaran rotaran is offline
Send a message via MSN to rotaran Send a message via Yahoo to rotaran Send a message via Skype™ to rotaran
Maybe the connections are corroded or the flasher is damaged. The flasher should be located left of the steering column. But first check the connections.
Even a wrong bulb (wattage) can cause this effect.
Mike
1991 Buick Park Avenue
1995 Ford Fiesta
Waghaeusel/Germany
Old 04-23-2004, 05:29 PM
Re: 93 Park Aveune 'intermittently' turn signal
I found it under the dash, left side of the steering column. I turned on the ignition without starting the car, turned on the turn signal switch and put my ear to the dash. I found the spot where it was clicking and reach up through all the wires until I felt the relay clicking. Pull it out and bought a new one. Done!
Old 04-23-2004, 05:30 PM
Found it and replace it!
Old 10-11-2009, 10:51 PM
Ih8tmyprkave Ih8tmyprkave is offline
Angry Re: 93 Park Aveune 'intermittently' turn signal
I found the flasher can THANK YOU GUYS SO MUCH BUT I am unable to get the blinkers to work still the hazards work but no turning indicators work at all is there a dammedable relay someplace that is not working and if so PLEASE tell me wher the darn thing is or send me a stick of 90% dynomite so I can kill this POS once and for all it has been a great car but I NEED my blinkers
