Old 04-22-2004, 12:24 PM
3grams 3grams is offline
Question Keyless Remote Program Info - 04 Pontiac Grand Prix GTP?
I would like to know if anyone out there knows how to program a 2004 Pontiac Grand Prix GTP keyless remote? 2 came with the car and I got spares on Ebay & the dealership wants big $ to program them (I think i've given them enough of my money for the car). 4 button remote. Your is greatly appreciated. Programming instructions or a link would be terrific. Thanks!
2004 Pontiac Grand Prix GTP - CompG
Old 05-02-2004, 10:05 AM
Aqualls1 Aqualls1 is offline
Re: Keyless Remote Program Info - 04 Pontiac Grand Prix GTP?
I have the instructions for 99 GM somewhere I used them on my 99 Grand Prix and Venture. I think they will work for you. I will look for them.
Old 05-02-2004, 06:32 PM
e2helper e2helper is offline
I don't think instructions for a 1999 will be applicable. Service Manual says that 2004 requires use of scan tool for reprogramming
Old 07-12-2004, 02:35 PM
crespo32 crespo32 is offline
Thumbs up
All transmitters which are to be recognized by the remote control door lock transmitter (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode it will erase all previously programmed transmitters upon the receipt of the programming signal from the first transmitter. Up to four transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle.
Remove the ignition key from the ignition lock cylinder.
Close all of the doors.
Remove the MALL PGM fuse from the fuse block.
Insert the ignition key into the ignition lock cylinder.
Turn the ignition to ACC. The body control module (BCM) will perform the following in order to identify the type of BCM installed in the vehicle:
Flash the seat belt indicator 1, 2, or 3 times.
Chime 1, 2, or 3 times.
Turn the ignition to OFF, and then back to ACC within 1 second. The BCM may begin to chime and flash diagnostic trouble codes (DTCs). If the BCM has stored any DTCs, refer to Diagnostic System Check - Body Control System in Body Control System.
Open and then close any vehicle door. The BCM will chime in order to confirm that the programming mode has been entered.
Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for approximately 14 seconds.
Important
After approximately 7 seconds the BCM will chime once to confirm that synchronization has been completed. After approximately 14 seconds the BCM will chime a second time to confirm that the programming has been completed.
Repeat the previous step in order to program each additional transmitter.
Install the MALL PGM fuse into the fuse block.
Operate the functions of each transmitter in order to verify correct system operation.
Old 08-16-2015, 05:54 PM
gerrly26 gerrly26 is offline
I have a 2004 Pontiac Grand Prix GT2 It says in the instructions to shut all of the doors and then remove the MALL PGM fuse. Problem #1 I cannot get to the fuses when the doors are shut. Problem #2 there is no fuse call the MALL PGM fuse. Can someone please help me with this?
Old 08-16-2015, 09:22 PM
Stealthee's Avatar
Stealthee Stealthee is online now
Your worst nightmare
04+ requires dealer to program, or at least someone with a Tech2. Those instructions are for a 97-03 and will not work.
