sr20det ?'s
i have a sr20det question maybe someone can help me with
i have a 92se sentra what i need to know is what will i need in order to make this swap work i read you need axals off a se-r are they talking about the drive axial(maybe thats the only type that will fit since it is a 2.0) or axal hubs(so my axal hub wont crack) or will both mine fit and work properly thanks and i might have a few more ?'s down the line |
Re: sr20det ?'s
Nope, you need the entire drive axle, the SE-R maf sensor, and the SE-R ecu.
SR20 powered SE-R: 60mph-6.2 sec., 1/4mi.-14.7 sec. VG30 powered Maxima SE: 60mph-7.8, 1/4mi.-15.8 sec. ![]() Don't make me ANGRY Or I will kick you in teh NUTS Your NUTS will feel teh steel toe Teh steel toe that has been in teh snow I will rip off yuor pants and kick yuo in teh nuts My steel toe will stick to yuor nuts And I will swing yuo around by yuor nuts as I do a Hurricane kick |
Re: sr20det ?'s
i cant use the maf sensor from the clip i receive and the SE-R ecu from the clip
the drive axles that come with the clip wont work? |
Re: sr20det ?'s
No, the axle needs to be from an SE-R. I didn't know you were using a clip. So yes, you can use the MAF and the ECU. Get the ECU programmed by Jim Wolf Tech.
