Old 04-22-2004, 08:00 AM
macavelli04 macavelli04 is offline
Send a message via AIM to macavelli04 Send a message via MSN to macavelli04
Eclipse or talon????
Which one is better.... an eclipse or a talon or are they the same? i kno that the eclipse's are more expensive and theres a little difference in the body style and maybe the interior but i dont kno if theres any difference with the engine or tranny or anything... what about the AWD turbos or just the fwd turbo's...
Old 04-22-2004, 08:05 AM
real_madridcf's Avatar
real_madridcf real_madridcf is offline
Send a message via AIM to real_madridcf Send a message via MSN to real_madridcf Send a message via Yahoo to real_madridcf
Check the sticky at the top of the page named "Read this before you ask a question". Then look under the reference portion of it. Click on any of them (i recommend the third one), and you should be able to find answers to many of your questions w/ out waiting. Its just that, some ppl get tired of answerin questions like these everyday, no offense.
Good Luck!
95 Eclipse GS: OBX Full Exhaust System, OBX Headers, OBX Short shifter, OBX Spark Plugs & Wires, 17' MSR Rims w/ Wanli tires
96 Eclipse GS-T : K&N Filter w/ Hardpipe, UICP & LICP, Greddy Type S bov, Greddy Boost Gauge
Hala Madrid!
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: Eclipse or talon????
Same. Just cosmetic difference.
Also the laser
For Sale 98 Eclipse GS, 5 spd
Old 04-22-2004, 08:44 AM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
the laser actually isnt exactly the same engine wise it has a slightly bigger turbo thats different from talon eclipse turbos
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 04-22-2004, 10:00 AM
sorry bout that...sometimes its hard to search for it and find it quickly....but why are the eclipses cost more than the talon?
Old 04-22-2004, 10:01 AM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
Re: Re: Eclipse or talon????
that i assume mitsus name over Eagles
Old 04-22-2004, 10:07 AM
coldhell9 coldhell9 is offline
If you are looking for a used model the prices should be about the same. There will be an obvious price difference between a turbo model and a non - turbo model. And the cars are pretty much the same. They rolled off the assembly lines rigth next to each other. These are great cars and very reliable if you maintane them. Good luck!
Old 04-22-2004, 06:38 PM
FourG63 97GST FourG63 97GST is offline
Send a message via AIM to FourG63 97GST
can u prove this?
-Agim
Old 04-22-2004, 07:20 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
i personally like the body stylings better on the eclipse thatn the talon
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 04-22-2004, 08:18 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
It's just hard to explain that your Chrysler needs a Mitsu stock part. "Well, you see.. napa guy, back in 1989..."
Old 04-22-2004, 10:27 PM
i like the eclipse styling better but if theres a huge
price difference between the awd's then ill take the cheaper one...
Old 04-22-2004, 10:29 PM
which would be more reliable the 2wd turbo's or the awd turbos?
Old 04-22-2004, 11:30 PM
JoeWagon's Avatar
Banned
let's put it this way. if you have AWD, it can break... if you don't have it-- you'll never have to worry about it.
same as: if you have a turbo, it can break... if you have a honda, you'll never have to replace a turbo.
duh, do you WANT awd? then get it.
Old 04-23-2004, 07:45 AM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Kris
2012 Genesis Coupe 2.0t
Old 04-23-2004, 07:49 AM
911S_TARGA_RSR 911S_TARGA_RSR is offline
Waste...Of...Bandwidth.
911 Super Targa RSR
[Dual Flow Intake][Twin Turbo][Larger List to Come]
