Old 04-22-2004, 02:17 AM
rubix777's Avatar
rubix777 rubix777 is offline
Send a message via AIM to rubix777
Creaking from the clutch
I've been having this problem now for a while. While releasing the clutch, it makes a creaking sound like one of the bolts isn't securely fastened. It also makes this sound if I release the gas quickly while it is in 1st gear. If I rock the car a little(apply a little gas, then take foot off gas) it'll also make this creaking/rocking sound.
I know for sure that it is not the suspension, it must be coming from the drivetrain.
Just today, when I released the clutch in first, it made a noticeable snap before it engaged.
Old 04-22-2004, 10:34 AM
gsrinteg gsrinteg is offline
Re: Creaking from the clutch
Has this car had work done on it before? I did a clutch in my car and my car was making the same sound, and it was just a lower tranny mount that wasnt tightened all the way. I would say its probally something stupid like that. Take a look for your self. Good luck
Old 04-22-2004, 04:10 PM
rubix777's Avatar
This car has recently had an engine swap done.
Old 04-24-2004, 07:18 PM
rubix777's Avatar
I looked under my my car near the drivers axle and it turns out you were right. it is missing one lower mount bolt. The transmission is separating a little from the engine block. Anyways, I ordered some from a Honda dealer and I should be getting it soon.
