Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 04-21-2004, 10:06 PM
sk8trk sk8trk is offline
oil leak what to do?
oil being sucked up through the valve cover vent hose and into the air filter housing. I have a Haines manual, can't find out my problem. Can anyone Help?
Old 04-22-2004, 02:31 PM
natenelsen natenelsen is offline
Send a message via Yahoo to natenelsen
Re: oil leak what to do?
First things first make sure that the oil level is correct, and that the vacuum hoses are hooked up correctly. If all is well here then...
remove the oil fill fill cap from the valve cover, is there a lot of gas comming out, what happens when you goose the throttle, does it suck a little, or just keep blowing out? (carefull you dont get hot oil in your eyes) The engine may even die when you take off the cap, I reccomed if it dies or if it "blows" out of the filler hole with the fill cap off that you do a compression test on the engine and see what your compression looks like in all (four?) holes.
Ps Year, model, engine, tranny and any other info on the truck would help, has recent work been done to it, any info you gives will help us give you as much of the benefits of our mistakes as possible
Nate
Old 04-27-2004, 06:02 AM
amac209 amac209 is offline
Send a message via MSN to amac209
also check for a clogged pcv valve. did you clean your throttle body? it's probably gummed up with crap too.
Old 05-19-2004, 08:10 PM
thanks for the ideas. will try them tomorrow, am printing them now. your ideas are tremendously appreciated. will let you know. by the way, 1986 truck, 22R engine, 4-speed manual, normally aspirated(carb). no work done recently, thanks again nate and amac
