Old 04-21-2004, 08:52 PM
sraymond sraymond is offline
Unhappy 95 blazer driver mirror replacement
I have a 95 blazer and the driver mirror fell off. I need help with installing the new mirror (especially the removal of the door panel). THanks
Old 04-22-2004, 08:05 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
in the arm rest yuou will see a little cover, pry that up with a thin screw driver, remove the 2 7mm screws... Pull the door panel from the bottom out and then the sides, lift off, disconnect the controls for the windows, set door aside... remove the 3 scres holding the old mirror on, set aside, pull mirror out and disconnect the wires, install in reverse...
Old 04-23-2004, 05:18 AM
cobra1 cobra1 is offline
aside from the two 7mm screws, there should also be a plastic screw that holds in the trim piece/lock slider behind the interior door handle.
also, if you have power windows, you will need to lift the switch section out and disconnect the switches before removing the door panel. lift up on the end closest to the dash, and it should come right out. much easier to remove it first as the electrical connectors are tight, and hard to remove, at least on mine.
