Old 04-21-2004, 08:19 PM
ahdi7 ahdi7 is offline
Send a message via AIM to ahdi7
Unhappy window keeps poping out of track!
i take out my plastic door panel and pop the window back into the tracks, i tighten the bolts to make sure its tight and secure. but when i roll down the windows again. it jsut pops out again.. how should the track look . should i bend it in or out ?? replacement? how much? 96 civic ex
Old 11-07-2004, 07:03 PM
stevevit stevevit is offline
I've got a 93 and have the same problem. I've taken the door panel off and reset the window where it seems to be but as soon as i start open/close the window pops right out of the track. I've taken this thing apart nearly 10 times and can't seem to get it right, maybe something is wrong with the track?
Old 11-07-2004, 11:04 PM
honda_luvr_2000 honda_luvr_2000 is offline
Re: window keeps poping out of track!
My cousin had the same issue. i fixed it for him about 6 months ago and it's still in the track last i heard. it was his drivers window, and it was popping out at the end toward the front of the car. when i was resetting it, i bent the track toward the back of the car sum (toward the other end of the window), and then tightened it. seems to have worked, so u might give that a try. i know it was a pain in the ass, so good luck.
Old 11-08-2004, 11:46 AM
Mistaphace Mistaphace is offline
I also had this problem. I had to replace the window runner (rubber that lines the entire window). That turned out to be ripped at the end closest to the seat beat area, it would push my window off track.
I hope this helps if you haven't taken a good look for rips.
I went to the junkyard and pulled out an old liner, but I noticed they stretch. $70 bucks from honda.
Old 11-08-2004, 06:02 PM
snowman2005's Avatar
snowman2005 snowman2005 is offline
Send a message via AIM to snowman2005
did the same and now it works better than my drivers side win. i did mess around with the tracks and the riser assembly.(i have teh manual door crank style)
ive got manuals
92-95 civic 96-98 Civic
clicky here clicky here
WTB:92-95 EX/SI cluster w/tach
FS:*NEW* 92-95 civic coupe black floor mats(4). pm me for pics or offers
Old 11-10-2004, 01:09 PM
Me too.....manual crank BABY!!
93 Hatch si
i/h/e
ACT Stage 1 w/ lighten flywheel
