Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 04-21-2004, 05:45 PM
DanzTacoma DanzTacoma is offline
Glowing Red Hot Header, normal?
Hi, i have a 2.3L 4 cyl 1992 ford ranger, after driving my truck for 5-10 minutes, i pop my hood to notice my header is glowing red. Is this normal? or no?
Old 04-21-2004, 09:45 PM
2000mudder's Avatar
2000mudder 2000mudder is offline
Re: Glowing Red Hot Header, normal?
i would say no! check exhaust for a blockage. unless you are beating on it for 10 minutes
Old 04-22-2004, 01:04 PM
lakerfan1784 lakerfan1784 is offline
Send a message via AIM to lakerfan1784 Send a message via Yahoo to lakerfan1784
a lean-burn condition causes a red-hot exhaust manifold. Go to an autozone and have them do a code scan...
Do sober what you say you will do when you're drunk. that will teach you to keep your mouth shut.
Old 04-23-2004, 11:48 PM
97chevyman's Avatar
97chevyman 97chevyman is offline
do what 200mudder and lakerfan1784 said, check the cat, they can plug up pretty easy. As for the lean burn thing, it could be the problem, but commonly people will not change the o2 snesors on time and the will plug up and make the vehical run rich, the when lean there is too much oxygen in the exhaust and acts like an oxyacetelyn torch and has a chemical reaction between the oxygen and the iron. I would suspect the cat first though.
